Evo 8 Megan o2 problems
Old Sep 1, 2012 | 03:10 AM
re-rx7's Avatar
Installed yesterday and it seems as though now the Megan o2 made the DP(also Megan) sit higher. The DP is hitting the transfer case(small corner of it) and tunnel. Feels like there is quite a bit of tension pulling the DP up and not free. Any ideas guys?
Old Sep 1, 2012 | 04:27 AM
TommiM's Avatar
I have a megan 02 sitting in the garage right now. I compared it to my oem one and it did seem like it was a little shorter iirc. I know that there are some setups that are meant for acd and non acd cars, if that is any help. It still uses the oem spring bolts, so you may want to try and see if stiffer exhaust mounts like the kartboys may help 'pull' down the exhaust enough for ya.
Old Sep 1, 2012 | 06:41 AM
re-rx7's Avatar
Its literally rubbing on my transfer case and front subframe. ARRGGHH!!! no play whatsoever. Regretting buying it.
Old Sep 1, 2012 | 12:07 PM
hermin0000's Avatar
dang I have one waiting to be installed please keep us updated!
Old Sep 1, 2012 | 12:10 PM
CDrinkH2O's Avatar
I have a Megan O2 and 3in Megan DP on an 8 with ACD, stock exhaust mani - no rubbing.
Old Sep 1, 2012 | 01:13 PM
re-rx7's Avatar
Does yours have a flex section?
Old Sep 1, 2012 | 01:14 PM
CDrinkH2O's Avatar
If you're asking me - no.
Old Sep 1, 2012 | 01:23 PM
The Unknown's Avatar
I don't have mine installed anymore but definitely didn't have any problems
Old Sep 1, 2012 | 01:26 PM
sujinX's Avatar
does your car have acd? there are 2 versions for the downpipe. one for acd and one for non. i have both the megan o2 and downpipe and i couldnt be happier for the price. no rubs or anything.
do u have the donut gasket on the o2?
Old Sep 1, 2012 | 06:35 PM
re-rx7's Avatar
Im gna check to make sure that donut is still on there.Are both flanges supposed to sit flush with one another? What are the differences in acd and non acd downpipes. Pics? Im a 03 evo 8 no acd.
Old Sep 1, 2012 | 06:41 PM
TommiM's Avatar
If your using the oem spring bolts then no it will not sit flush.
Old Sep 1, 2012 | 07:15 PM
re-rx7's Avatar
Interesting as i see now with the oem spring bolts it is sitting flush. Itwas installed at a shop. So im guessing here, that if the donut gasket was not installed then that extra 1/2" of space or less is lost.
Basically there will be some gap in the dp and o2 housing with the Oem donut installed.
Old Sep 4, 2012 | 08:43 PM
CDrinkH2O's Avatar
Interesting as i see now with the oem spring bolts it is sitting flush. It was installed at a shop. So I'm guessing here, that if the donut gasket was not installed then that extra 1/2" of space or less is lost.
Basically there will be some gap in the dp and o2 housing with the OEM donut installed.
You are correct. It sounds ike they didn't install the doughnut.
Old Sep 4, 2012 | 08:55 PM
sparky's Avatar
Originally Posted by TommiM
......you may want to try and see if stiffer exhaust mounts like the kartboys may help 'pull' down the exhaust enough for ya.
This. Install the Kartboys only along the side of the DP & exhaust pipe(s) furthest away from the contact area. Install the soft stock mounts on the side of the exhaust closest to the contact area. Since the stockers have more give they will stretch away from the TC thus allowing the exhaust pipe to shift about 1/2" axially over to the driver's side of the chassis, as the Kartboys "pull" the pipe away from the TC.
