Grinding Noise - (Video)
Old Sep 12, 2012 | 04:37 PM
addikt's Avatar
So there is a grinding noise at idle just like in the video. Push clutch pedal in (even barely) and it goes away, rev with the clutch pedal in and the grinding comes back. While in gear, anywhere above 3k rpm there is a loud "whirling" noise when I let off the accelerator. Goes away as soon as i press the accelerator.
I also took a photo from the inspectors hole of the trans. It is an Exedy Twin.
Old Sep 13, 2012 | 06:00 AM
addikt's Avatar
Bump
Old Sep 13, 2012 | 09:40 AM
blowngasket's Avatar
could be a number of things, hows your trans oil look? To me it sounds like its a trans issues, possible bad bearing or slider or worn Shift fork. Any of the gear skip out of gear or are hard to engage? check the trans oil level and oil for shavings.
I say trans cause it goes away when ya push the clutch in, thus making eveything in it stop spinning. givin the fact your not moving of course.
Old Sep 13, 2012 | 10:38 AM
addikt's Avatar
Trans oil is at the correct level but I have not looked to see if there are shavings. The car drives fine, goes in gear everytime and no slippage.
blueprint
Mar 27, 2017 11:29 PM
Dross99_si
13
Sep 16, 2016 10:57 PM
bigfoot1612
24
Jul 9, 2014 06:21 AM
Ichigo0Soul
21
Mar 26, 2014 05:43 AM
bdonIX
Dec 18, 2012 02:22 AM
