i hate driving this car!!
Old Sep 15, 2012 | 10:24 PM
  #61
spadednick88's Avatar
Ok ill give it a shot
Old Sep 15, 2012 | 10:51 PM
  #62
CurseDSM's Avatar
Originally Posted by spadednick88
My vacuum at 1k is at 12. I bumped it uo a tad to 1.3k and it sits at 15. Btw i had an alright starting map for him he just setup sd for me. It took about an hour or so, so def coulda missed something
At 1k and that is where I would go back down to, you would need a white spring for that. I know you said you are gonna change springs or you did already but that is the proper spring to use. If the car still does it then yeah its definately tune related. I went back and saw you got a black spring. That will work but being it is a softer spring, it will open under throttle and make things worse. I went through like 3 springs myself and that wasn't even the problem. Tom fixed it the min he tuned it from my last tuner.
Old Sep 15, 2012 | 11:13 PM
  #63
Ok i have white spring in now
Old Sep 16, 2012 | 04:55 AM
  #64
ToddRhodes's Avatar
Edit - nm, I was reading for a 50mm, not the Q. White should be the spring to use...
Old Sep 16, 2012 | 07:42 AM
  #65
CurseDSM's Avatar
Funny you said that because I had to look it up a few times to make sure I was correct after I posted
  #66
CurseDSM's Avatar
Yeah if the spring is in now then it definately sounds like a tuning issue or your map just needs to be smoothed out a little
Old Sep 16, 2012 | 08:31 AM
  #67
Ricekiller81's Avatar
From Local Cars in my area the injectors you are using seem to be the issue for the most part. I'd say try an ID2000 cc inj and have an E.R, Tscomp, or Mellon or have these guys I mentioned recommend an appropriate Injector. Hope you get everything sorted to enjoy the car man.
Old Sep 16, 2012 | 09:16 AM
  #68
06MRV8Killer's Avatar
This or Precision with an aeromotive FPR which is what I had to switch to when my FIC 2150's were giving me a hell of a time. Precisions will work just as well as ID 2000's without costing you as much money.
Old Sep 16, 2012 | 09:35 AM
  #69
Hearts_Fitment's Avatar
One step stiffer than white. I forget the color at the moment.
Originally Posted by SyZyGy1394
Well, what spring are you using?
Old Sep 16, 2012 | 10:26 AM
  #70
CurseDSM's Avatar
That would be black and that would cause compressor surge. I tried one heavier and one lighter and the lighter one just opened to early and the stiffer one compressor surged big time.
Old Sep 16, 2012 | 10:28 AM
  #71
CurseDSM's Avatar
Why did you have to switch to a afpr was there something wrong with your stock one? Plenty of people run double pumpers and 2150s with stock regs without any issues.
Old Sep 16, 2012 | 10:54 AM
  #72
silverofs's Avatar
The 40r is proven to suck at this altitude I bet it's just surging like crazy and there is not much your going to be able to do about it. There are literally no fast cars that run a 40r variant in the Utah area because of these reasons. Good luck though
Old Sep 16, 2012 | 11:31 AM
  #73
Funny u said that when it starts getting cold im thinking of going to 35r or 6262. This turbo isnt cuttin it for drag
Old Sep 16, 2012 | 12:35 PM
  #74
TpArK's Avatar
Hmm some people are telling me softer spring and u changed to stiffer?? Hmm something to think about
Swapping springs, or even making adjustments is a fairly quick procedure. I would just play around with it until you find your sweet spot. I originally had the same doubts as you as a softer spring seemed to make more sense.
Old Sep 16, 2012 | 12:53 PM
  #75
Update! Well guys i was going off ur guys hunch about the bov. I just went n checked the spring to make sure the kid that sold me the bov was right that it had the white. I popped it open and wahla the dam spring is purple!! Ha. I also looked on tials sight and they said it needed direct vaccuum from IM and i have the line t'd to my boost a pump. Im ordering a vaccuum distribution block and a new spring tonight hopefully it fixes it. Thanks for all ur help
