MAF Sensor?
Old Oct 2, 2012 | 05:55 PM
Yiyo's Avatar
MAF Sensor?
I need help? How to eliminate the MAF sensor with the OEM ecu. Anyway to do this without changing the ecu??
Old Oct 2, 2012 | 05:59 PM
evo8426's Avatar
Run speed density, it requires tuning.
Old Oct 2, 2012 | 06:03 PM
itsmrrizz2you's Avatar
speed density... omni map sensor and a iat
Old Oct 2, 2012 | 06:07 PM
Yiyo's Avatar
So that way I can eliminate the MAF sensor
Old Oct 3, 2012 | 12:29 AM
evilempire76's Avatar
Yes it will eliminate the stock MAF sensor. You need help from a professional tuner for this.
Old Oct 3, 2012 | 12:37 AM
feautoevo's Avatar
What are you trying to achieve by eliminating the MAF? You can run a blow through setup like a GM 3" with maf translator and this will allow for much less restriction and the ability to VTA your blow off valve, lol.
Pm Me after you research your options, I have a GM maf and translator for sale.
Old Oct 3, 2012 | 12:52 AM
Eno-Evo's Avatar
The stock ecu is able to eliminate the maf sensor with the rite components and tune, its the best rought
Old Oct 3, 2012 | 06:49 AM
evo8426's Avatar
I'm not a professional tuner and I made the switch
Old Oct 3, 2012 | 06:53 AM
You made the switch cause u know what ur doing. Not all of us can tune speed density it's not the easiest to do on a stock ecu
Old Oct 3, 2012 | 07:08 AM
Yiyo's Avatar
How easy is ? Any place to find the steps?
Old Oct 3, 2012 | 12:19 PM
Kracka's Avatar
Search, it's been well documented.
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
mikane24
For Sale - Part Outs
Oct 22, 2014 06:20 AM
blackevolution8
May 21, 2013 09:29 PM
mikane24
May 8, 2013 01:33 PM
NZEvox
Feb 10, 2013 01:40 AM
