What is this pipe called?!
Old Oct 17, 2012 | 02:00 PM
Heezayx's Avatar
ive been having problems with this pipe for a whole now, i have a boost leak at the point where this pipe connects to my turbo.... it seems like noting i do will fix it ive tried to put a high temp sealer and it has done nothing. I think the end of this pipe might be beveled. suggestions please?!
Attached Thumbnails What is this pipe called?!-561702_4550598213310_48857891_n_zps370b5787.jpg   What is this pipe called?!-622076_4550595253236_907527013_o_zps5f0c163c.jpg
Old Oct 17, 2012 | 02:07 PM
SavageEvo8's Avatar
turbo compressor outlet pipe
Old Oct 17, 2012 | 02:15 PM
Heezayx's Avatar
thank you
Old Oct 17, 2012 | 02:16 PM
evo8426's Avatar
That is the FP Race Pipe or Buschur J-Pipe, it replaces the stock J-Pipe.
Have you tried a new gasket instead of using RVT?
Old Oct 17, 2012 | 02:20 PM
Heezayx's Avatar
Originally Posted by evo8426
That is the FP Race Pipe, it replaces the stock J-Pipe.
yes ive tried a new gasket as well, the bolts are a real pain in the a** to get to and loosen because everything is in the way but once i got the pipe out the gasket that was on there was fine, but i still changed it anyway
Old Oct 17, 2012 | 02:34 PM
Ev0ikon's Avatar
Take off about 1 mm on a flat grinder/sander.
Old Oct 17, 2012 | 10:13 PM
denver89's Avatar
definitely the j pipe..but that flanged end looks weird like one of the bolt hole has been cut and the mating suface looks bowled instead of flat.. maybe its for a different turbo...what i would do and your best bet...is to buy a stock one i usually see them for about $50 good luck
Old Oct 18, 2012 | 08:32 AM
Ev0ikon's Avatar
The bolt eyelet cut is normal. That is to allow for some adjustability.
What you should check for is a flat surface at the flange. Hi-temp RTV is also a good idea in that area.
Old Oct 18, 2012 | 10:16 AM
Heezayx's Avatar
yea im going to take it out and make sure the flange isnt beveled because that is where i have the boost leak... also i do have the hi temp RTV on there
Brandonliburdi
Jan 8, 2017 05:48 PM
TxFAkuma
Jul 8, 2016 08:10 AM
joonvang
Jun 6, 2016 03:27 PM
evolution4.7
Feb 18, 2015 09:44 AM
