A few boost questions
Old Nov 1, 2012 | 08:09 AM
jmac13's Avatar
If it still doesn't work I'd start checking your wiring and your vacume lines might be wrong or even the ports on the solenoid could be wrong as well.
Old Nov 1, 2012 | 07:37 PM
89Saleen141's Avatar
Originally Posted by will1311
Just to make sure, you are only pressing and holding the left button for 2 seconds to change from OFF to A and then to B, correct?
Because if you leave it in A, it should be there still when you shut off and then turn the car back on.
And also just making sure, you have port 1 open, port 2 to the wastegate and port 3 to the boost source, correct?
Shoot.... yeah i fixed it thanks. It was off. I thought by going through the settings it was adjusting it and by going to run mode it turned it on. I held down the button to switch from off to A and its working beautifully. Thanks for your patience and help everyone.
Old Nov 2, 2012 | 04:39 AM
will1311's Avatar
No problem, Now go have some fun with it
VRP
Mar 24, 2014 04:43 AM
TJung
Feb 13, 2012 02:02 PM
fxyxixe
Nov 4, 2010 09:33 PM
2005evo8gsr
Oct 16, 2010 02:41 PM
