shifter bushings Need some input
Old Nov 25, 2012 | 07:59 PM
elim0's Avatar
+1 OP - have you got your torque solutions yet? i've been looking at base and under hood bushings too (from torque solutions) , as well as drive shaft bushings, will it make the car more smooth and better daily drive feel ?
edit: also does torque solutions under hood being delrin material mean they dont need to be greased/lubed up ?
Old Nov 27, 2012 | 02:34 AM
ninj4sevo8's Avatar
both the underhood and base bushings are definitely a good mod, you can also upgrade your transmission fluid for a smoother feel, and if you really want to "shift likes its butta" as some would say, upgrade your trans and TC, either bushwacker or shep trans
Old Nov 27, 2012 | 07:25 AM
hempele28's Avatar
I did the bushcur under the hood and shifter base bushings along with a front motor mount all at the same time. Personally i felt the shifting was a bit smoother. I beleive you can pick up the torque solution shifter base bushings off amazon for $21 shipped. Its a nice inexpensive mod. You can also pick up their front motor mount for $75 with free shipping off amazon. I would recomend doing both at the same time.
Old Nov 27, 2012 | 07:30 AM
kaonashi's Avatar
I got both under hood and shifter base from a vendor on Ebay both torque solutions for 44$ shipped. They made a world of difference in shifting. It is certainly more firm and precise haven't had any issue getting into gear after installing them.
Old Nov 27, 2012 | 08:28 AM
elim0's Avatar
cheers for the reply ! i ordered my torque solutions base n cable bushings and are otw ! i also added the driveshaft ones too. i didnt get rear diff/mustache ones yet as i dont have a press and am jst doing DIY installs, also i've heard they might b different as i have a JDM evo8. i already have torque solutions front MM, am looking forward to these !.. raced a 600cbr before, without a doubt i was going to lose, but i missed 4th which made it even worse .. for some reason i miss 4th the most, of all gears ?? lol !
Old Nov 27, 2012 | 08:39 AM
kaonashi's Avatar
Yeah After i replace my clutch I'll be getting all new motor/tranny mounts and all the driveshaft/rear diff once I get everything lined out.
domyz
Feb 14, 2013 10:07 AM
rmondoh
North Texas Evo Club (NTEC)
17
Dec 14, 2012 02:05 AM
Kracka
25
Nov 14, 2008 05:50 AM
bolsen
May 4, 2005 07:20 PM
PDXRalliArt
Jun 25, 2004 01:16 PM
