System to lean code and breaking up between shifts?
Old Nov 17, 2012 | 03:44 PM
ReignMan24's Avatar
alrite guys, quick question, i already searched a bunch about the whole system to lean code(p0171) i believe thats the number, neways, i replaced sparks plugs thinkin that may be the intial, well the only problem i found at all when i replaced them is they were quite loose and not tighten down very well into the head, so i tighten them, cleared the code, and every couple days it will come back on for no reason? the other issue is between shifts at WOT the car with break up a bit the go, and through the entire rpm band it will b fine, only time it breaks up is between wot shifts, and i noticed today that in between shifts it blew a small cloud of black smoke? yall think it may b goin rich in between? ne help would b great
Old Nov 17, 2012 | 07:21 PM
ReignMan24's Avatar
sumone has to of had this issue before? come on guys
Old Nov 18, 2012 | 12:51 AM
Thore's Avatar
Mods?
What kind of DV/BOV are you using?
Tune? Mods since the tune?
Old Nov 18, 2012 | 09:22 AM
ReignMan24's Avatar
tune was done by tscomp, so i knw its nothin bad on that end, was fine during tuning stage and even when we finished, just recently started
Old Nov 18, 2012 | 09:38 AM
Boosted Tuning's Avatar
If your getting the system lean code, that means your injectors are not scaled correctly and your fuel trims are outta wack.
Old Nov 18, 2012 | 04:19 PM
ReignMan24's Avatar
its weird cuz it just started recently happening...ill talk to my tuner and see what he has to say, thanks for the input
Dochka
Oct 26, 2021 01:01 AM
smg944
Jan 1, 2015 05:47 PM
Keith6110
Lancer Troubleshooting
Jul 28, 2014 06:35 AM
sirchumpalot
27
Nov 28, 2012 12:07 PM
LVSBB6
Mitsubishi TC-SST Discussion
25
Feb 16, 2010 10:56 AM
