bad idle with cylinder 4 compression@20psi
Old Nov 26, 2012 | 06:43 AM
EvoAznBoi's Avatar
Hi every 1
I have an evo 8
Mods
Gsc s1cams
Witth normal bolt on and running stock turbo and a tuned
Having idle issue with a 4th cylinder compression at20psi . I changed the plugs, wires, crank and cam sensor, clean and checked the iac, and maf. Did the timing yesterday everything is tdc and still having issues.
Can someone shine some light on my issue plz
Old Nov 26, 2012 | 06:53 AM
gsrboi80's Avatar
You are saying that on a compression test Cyl 4 is at 20?? Assuming you performed compression test properly. That's your issue
What are you seeing in the other Cyl's?
Old Nov 26, 2012 | 08:18 AM
EvoAznBoi's Avatar
Cylinder 123 has 170psi and 4 only at 20 psi
Old Nov 26, 2012 | 08:23 AM
Macaroni's Avatar
Did you do a wet test or dry test?
03evo_joe's Avatar
sounds to me the rings are shot on cylinder 4 or you have a blown head gasket, how many miles on the car??
Old Nov 26, 2012 | 08:30 AM
EvoAznBoi's Avatar
its at 140,000 i did dry test
Old Nov 26, 2012 | 11:44 AM
mt057's Avatar
Do a leak down test so that you can see where the loss is happening. Could be some bent valves. The leak down will help you know.
Old Nov 26, 2012 | 12:25 PM
Spec-Ops1's Avatar
If you do not know what a wet test is, put a cap full of oil in the low cylinder and redo the test and see if the compression goes up... if it does it is your rings, if not then either headgasket or valves or something in the head... which is what a leak down will tell you...
Old Nov 26, 2012 | 12:36 PM
WHTEVO's Avatar
Get ready to take the engine apart. Like Freddie said, do a leak down test to help pinpoint the issue. But regardless, it's coming apart. Good luck.
Old Nov 26, 2012 | 03:35 PM
zenki-s13's Avatar
Sounds like you have a Subaru lol.
Thats your problem though. Your pretty much running on 4 cylinders. Do a leak down.
Old Nov 26, 2012 | 04:21 PM
EvoAznBoi's Avatar
okay took the head apart broken valve. i guess its time for a rebuild...
Old Nov 26, 2012 | 04:58 PM
Shortbus115's Avatar
That's a bummer. Any exciting plans running through your head or just bringing her back?
Old Nov 26, 2012 | 05:08 PM
EvoAznBoi's Avatar
times are bad now just need a car to drive. not sure how bad it is. looks like the spring broke and the valve was stuck down. and the other valve look warp. gonna take it to the machine shop to see how bad it is.
Old Nov 26, 2012 | 06:23 PM
Hitmachine101's Avatar
ah dam sorry to hear the valve broke on ya, just had a similar compression on cylinder 2 of my little 4 cylinder beater honda, 170 40 170 170, figured the motor was done because i am not tearing it apart, way to old and rusted to be worth my time, so did a little steam cleaning and sea foam through that old carborator and to my surprise got the compression back, the old hunk a junk needed the carbon broken up on those valves and she reseated
running well again so i was gonna suggest the old water and 2k rpms trick to see if you could get the compression back
good luck on the rebuild and keeping the bill down at the machine shop
lostsoulsevo
28
Feb 9, 2017 05:52 PM
riceball777
Dec 25, 2012 03:52 PM
car_nut15
Dec 16, 2012 09:03 AM
Pssst
Mar 8, 2012 12:26 PM
Chukee_R
13
Aug 20, 2007 01:36 PM
