help with downpipe guys!!!
Old Dec 10, 2012 | 06:31 PM
evo_yoshi15's Avatar
ok guys so I recently installed my exhaust on my evo 8 and everything was fine but as soon as I drove it I heard a clicking sound and I look under the car and my downpipe went down a bit cause of my exhaust weight I guess so now my downpipe hits my transfer case I think it is and its only at idle and high revs I have a turbo xs downpipe and invidia exhaust it also hits the braces but that's fixable wit some washers my main ? is how to fix my downpipe from not hitting the transfer case I tried moving a bit but the hangers I have (kartboy and oem tried them both) but still nothing so help guys plz cause its driving me crazy
Old Dec 10, 2012 | 07:42 PM
Shortbus115's Avatar
I get the feeling I'm going to run into this issue this weekend. Hopefully the Buschur DP I ordered today doesn't rub.
Anyway, you need a hammer.
Edit: I'm going to assume you have an 05 or an 06. Am I right?
Old Dec 10, 2012 | 08:03 PM
sparky's Avatar
I'll tell you what you gotta do since you have a full set each of Kartboy and OEM hangers. right? At least this is the way I solved it when I had a similar problem:
Imagine there is an axial centerline down the length of your exhaust. You'll want to only use the OEM hangers on the side closest to the contact area. That is use the OEM hangers on the passenger side of the exhaust. Install only Kart boys on the driver's side of the exhaust. Since the OEM's give and the Kartboys don't, this will pull the DP away from the TC. Combining hangers in this configuration, softer along one side, and harder on the other side, should accomplish what you want.
You may want to loosen the bolts at all the juncture flanges between TP/Cat/muffler/DP, etc.(finger tight), while you install the hangers. See how it all lines up, check for interference/contact, then tighten everything down afterward.
Old Dec 10, 2012 | 09:54 PM
its a 04.... yea thanks that sounds like it might jst work ima give it a try tomorrow
FALCO
21
Feb 15, 2011 08:18 PM
evo unknown
15
Dec 8, 2009 08:03 PM
cweav
49
Jul 8, 2009 04:36 PM
jrsimon27
31
Dec 11, 2006 04:17 PM
fatalbert69
24
Jul 10, 2005 04:27 PM
