Check engine light :/
Old Dec 21, 2012 | 03:18 PM
apham5's Avatar
So my service engine light just randomly comes on, and I have no idea what it is. Fluids are good, vacuum hoses are good, oil good. Maybe spark plugs? I recently just put a full turbo back exhaust on as well...ideas?
Old Dec 21, 2012 | 03:24 PM
hiboost2.0's Avatar
How long does it come on for? Use a code reader and look under the "Pending Codes" Section. That may steer you in the right direction.
Sil'vr-Boi6's Avatar
Service check engine light can be countless of things.. you need to pull codes. Advance autoparts, autozone or most auto parts store can read your car for you for free, Get a code and report back:
Old Dec 21, 2012 | 03:32 PM
Hitmachine101's Avatar
like the gentleman said go to get a free code reading, IGNOR WHAT THE autozone idiot will tell you he/she thinks it is,
( i can say that seeing as i worked ( yes past tence ) there and youd be amazed what people will say it baffles me, if there trying to sell injector cleaner as there monthly check out goal then they ll probably say its your injectors,, so here use this lol)
report back with the numbers it should be p then a 4 digit code or something close to that
if you just installed a full turbo back exhaust then your downstreem 02 might be tripping the code due to the fact there is no cat? dont know if you have one in there or not
let us know what you get with that code
Old Dec 21, 2012 | 06:43 PM
Mao's Avatar
Mao
Also note that you can get your own code reader if you have a smart phone for pretty cheap. Look up OBD2 dongle online and get one for about 15 USD and the application for it is about 5 USD. Though ordering the OBD2 online would come with a copy of the application on a disk.
Old Dec 21, 2012 | 06:56 PM
Dmav1989's Avatar
If u just put on turbo back exhaust I bet it's a P0420 for ur catalytic converter..nothing bad if its that code..just do the anti foul mod or have ur tuner turn of ur rear o2
Old Dec 22, 2012 | 03:51 PM
apham5's Avatar
arlight sweet thanks.
give me a few days to get the code, i live in cali and places lie auto zone wont do it anoymore, at least the one i went to said they wont, but ill get the code sometime next week and ill report back. thanks again!
Old Dec 23, 2012 | 08:04 AM
OC's Avatar
OC
I had the same problem. For about two weeks on and off my check engine light would come on. This was months after I installed a turbo back. I have a cel fix on my test pipe. I plugged in my Cobb ap and I had error code P0440. Evaporation emission Control malfunction. Basically my gas cap was bad. Got a new one and I've been riding clean for weeks. Good luck man.
Old Dec 23, 2012 | 09:37 AM
to the op, just buy a code reader man, youll need one if your to understand your cars issues, hate to say it but youll need a code reader more then once
Old Dec 23, 2012 | 09:51 AM
Cal City Evo's Avatar
For sure! And you need to be able to reset them also. A tool no one should be without now days.
Old Dec 24, 2012 | 09:10 AM
apham5's Avatar
so my service engine soon light turned off, so maybe it might be the same problem as yours or maybe it was a glitch idk....
Old Dec 24, 2012 | 09:21 AM
gsrboi80's Avatar
The code will still be stored. Get the code pulled
Old Dec 25, 2012 | 12:01 AM
OC's Avatar
OC
I just kept clearing the code until it stopped showing up. Have had no problem so far. Car runs great
Old Dec 25, 2012 | 03:05 PM
Throttle's Avatar
i can't believe nobody has mentioned evoscan. it will tell you the code and what it means. no need for anyone else to touch your car or buy some silly code reader.
JukEboXAuDiO
Lancer Troubleshooting
10
Apr 25, 2014 06:25 AM
newguyhere223
Jan 1, 2014 03:48 PM
haloevolution45
24
May 10, 2013 08:46 PM
that_guy206
Mar 22, 2013 05:13 AM
