Whats next??? Help! =)
Old Jan 29, 2013 | 09:53 AM
Mauricio Evo IV's Avatar
Hello guys! Im in the middle of a question!
What would be the best way to invest about $ 2,500 - $ 2,700 in my Evo IV...
Right now my car has stock intake manifold (ported and opened the inlet to 70mm), the UICP is custom and was made very bad by a shop here in my country and last, my car use stok MAF... (mods are in my sign). I always use the car for drag racing.
I had planned to buy a set of Hoosier QTP's tires, an intake manifold (Magnus, AMS, Map Rev2-3), maybe a Muse UICP (cheaper) and fuel lab fuel pressure regulator because my current fuel pressure regulator (aeromotive) has leaks ...
My goals maybe are 600whp, I would like to boost my Black to 40 psi, but I don´t know with my setup (intake manifold and FP Black) can get my goals?
So, what do you think and what do you do in my case? Any suggestions?
Old Jan 29, 2013 | 01:55 PM
Old Jan 29, 2013 | 02:02 PM
03evo_joe's Avatar
you could prolly go with larger injectors and what gas are you using and whats available in your area?
Old Jan 29, 2013 | 02:05 PM
loweyz's Avatar
nice mods, as long as you can keep your head stuck to the block more boost?, i think you have hit the limit on the black turbo dont quote me but im pretty sure they wont flow 600hp have you considered a garrett kit? also a standalone ecu with maf delete will help a tonne
Old Jan 29, 2013 | 02:20 PM
ecktt's Avatar
S3 cams & 340lph pump
Old Jan 29, 2013 | 02:21 PM
I use VP Q16 is the only race gas avalibable in my country. I think 1000cc are enough I think.
I don´t know, I saw some guys runing 40+ psi with black turbo. I considered a 6262 T3 kit, but for my budget its impossible. The problem with my car are tires, I have no traction with my current tires, for that I want to use drag radials, but I want a more power too.
Old Jan 29, 2013 | 02:47 PM
ctfpevoVIII's Avatar
Isn't there someone that has hit 750 whp on a black turbo? I think 600 whp is easily doable on c16 with some more boost, but I agree that you may need larger injectors.
Old Jan 29, 2013 | 03:04 PM
theres a lot of people above 600whp with black turbos. Right now using VP Q16 and boost to 35 psi the injectors are in 80% load.
But if I put an big intake manifold I think I will need more gas and if increase the boost yeah, i think I will need 1,150cc maybe right?
My question is, Do I need a bigger intake manifold for that power with my setup?
Some guys can tell me theres some evos running 650whp-700whp with stock intake manifold but the always use biggers turbos like 6266-6464, so that can be a good choice change the IM? If yes, wich one?
Old Jan 29, 2013 | 03:10 PM
flymx771's Avatar
6262 isn't much of an upgrade from a black. The stock intake manifold really isn't that restrictive until you start flowing massive amounts of air. With a better set of cams and a good tune you should have no problem making 600.
My 2.3l with a black and gsc s2 cams made just short of 700...and that was on an unported manifold and throttle body!
Old Jan 29, 2013 | 03:13 PM
loweyz's Avatar
yeh i understand about big horsepower runnin through a black yes theyll do it but you cant tune the car properly if theyre efficiency drops you can run mad hp through a stock turbo there just not efficient at higher revs but those are some big numbers your going for i know one other guy pushing for 650 atw ill ask him and get back with some dyno figures and a mods list
Old Jan 30, 2013 | 02:29 PM
Right now i´m using Kelfor 272°.. Do you think I can get more power or the same power putting the GSC s3 as it did with the intake manifold? For me that option is nice, because I will spend less money buying those cams. I can sale my cams after
LimitlessEvo7
Nov 9, 2014 02:53 AM
nzevo8
Sep 20, 2014 04:51 AM
Boost_Inspired
Jan 4, 2014 04:25 PM
tazz5425
107
Jul 14, 2013 01:45 PM
David Buschur
Oct 31, 2008 09:39 AM
