Removing Bottom Dash Piece
Old Feb 6, 2013 | 01:22 PM
EvoIXPilot's Avatar
Need to remove the dash part by steering wheel. I see only two to three screws. Is that it or do I need to remove the top portion first?
Old Feb 6, 2013 | 06:49 PM
barneyb's Avatar
I think it just comes off, 2 screws at the bottom and 3 clips at the top.
Old Feb 6, 2013 | 09:02 PM
Thore's Avatar
Yup, 2 screws and it just pops off when you pull.
Old Feb 7, 2013 | 01:59 AM
Teal2nnr's Avatar
The bottom portion is attached to the top, once the screws are out its easy to uncouple.
Old Feb 7, 2013 | 07:15 AM
Grimgrak's Avatar
Whatever you do dont force that bottom peice, you either have to tilt the steering wheel or take the bottom dash panel off below the clamshell assembly or you risk breaking the keyfob sensor thingy.
Old Feb 7, 2013 | 03:20 PM
EvoIXPilot's Avatar
So basically these two screws and pull?
Old Feb 7, 2013 | 03:21 PM
EvoIXPilot's Avatar
which panel should take off and where is the key fob sensor
Old Feb 7, 2013 | 06:01 PM
barneyb's Avatar
I'd first make sure there's slack in the wiring behind the switches. So take care of the wiring first if necessary.
I've had every panel off the dash the dash has and every one is an adventure. So, pull the screws and then do some careful prying until you get a sense of which way the clips go. Otherwise you are trying to break them off. Once it comes off it will look so simple but it pays to take your time.
Old Feb 8, 2013 | 10:11 PM
Grimgrak's Avatar
It's in the steering column lower half but I now see thats not what your trying to take off.
Old Feb 9, 2013 | 01:19 AM
Softishman's Avatar
What are the mini microphone thing in the picture, have 2 of thoose in my evo8 and I donīt know what it is...
robbieraver
Sep 3, 2015 10:57 PM
Amici2120
Apr 26, 2014 03:41 PM
bolsen
Sep 7, 2004 11:02 AM
EVO8speed
May 21, 2004 08:35 PM
Wolfe
Feb 13, 2004 08:09 PM
