Mirage coilovers similar to Evo V?
Old Feb 14, 2013 | 06:39 AM
YYANG's Avatar
I'm not sure if this is the correct spot to post this, but I've just recently picked up a 2001 Mitsubishi Mirage and have ordered some Evo V aero for her. I'm looking at coilover options right now and my question is, "are the Mirage coilovers the same as the Evo V's"? I will be upgrading to the 5 lug and brembos sometime in the future. I just don't want to have to purchase another set of coils. Thanks in advance everyone.
Old Feb 14, 2013 | 08:35 AM
BlackEvo_5's Avatar
Should be the same as they are the same chassis, the big difference is the rear end by the diff. The normal lancers/mirage doesn't carry the supports and bolt holes for the diff support member etc.
Old Feb 14, 2013 | 11:51 AM
YYANG's Avatar
That's what I thought too, considering it's an AWD vs. FWD. Might invest in some cheap coils to get me through til I save up for the drivetrain swap. Thank you.
Old Feb 15, 2013 | 03:49 AM
BlackEvo_5's Avatar
Old Feb 15, 2013 | 04:07 PM
ProPilot04's Avatar
No they aren't the same at all.
The rear is completely different. The front coilovers would "work", but the spring rates would be WAY off because of the huge weight differences.
I'd suggest popping over to mirageforums.net
Tons of experience over there.
Old Feb 15, 2013 | 04:15 PM
Yogi_B's Avatar
The non evo lancer/mirage struts are closer to the evo1-3 setup, except that they use a 3bolt strut top on the front instead of 2bolt.
Old Feb 16, 2013 | 07:04 AM
BlackEvo_5's Avatar
yes the front carries 3 holes vs 2 on the Evo but i know of 3 mirages/lancers here in Barbados that are carrying Evo coilover suspension on them without any issues.
Mitsu Colts can't use the rear suspension.
by his description he means the CK chassis.
Old Feb 16, 2013 | 02:21 PM
Yogi_B's Avatar
Then the would have modified it.
I can't remember if the mirage/lancers have the sway bar mount on the suspension arm or the strut, so that would have to be added on.
And the rear shock lower mount is different, evos use a fork with the bush on the arm while the mirage/lancer share the same rear suspension as the evo1-3 which has an eyelet mount with the bush at the bottom of the shock, so that would have to be modded.
Alchem1st
Mar 12, 2018 03:37 AM
Teal2nnr
Feb 21, 2016 08:31 AM
luckymarine0311
Nov 9, 2010 06:49 PM
MitsuJDM
10
Aug 26, 2008 09:14 AM
