fuel injectors
Old Feb 28, 2013 | 10:04 PM
bryonboals's Avatar
fuel injectors
is it common that a evo will not start when you upgrade injectors. Went from stock to 720
Old Feb 28, 2013 | 10:56 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
You need to tune the car after you change injectors IIRC.
Old Feb 28, 2013 | 11:13 PM
WikdEvo's Avatar
lol.. yea, you just might need a tune. Not quite sure though...
Old Mar 1, 2013 | 04:46 AM
ReaperX's Avatar
You need to have them scaled and adjust the start up enrichment and decay tables properly. If you just install the injectors and try to start you will flood the cylinder with fuel, and it wont turn over.
Old Mar 1, 2013 | 05:46 AM
steven121's Avatar
Scale injectors first, then do latencies make sure they are both close to zero, then do your enrichment tables, decay tables, last should. Be your maf compensation tables to ame sure your afrs are close to matching on your actual map.
Google merlins evo tuning guide
Old Mar 1, 2013 | 05:57 AM
evo8426's Avatar
It is not necessary or worth the time and effort to change the MAF scaling. Not everything has to be adjusted for new injectors unless you need additional work.
Making the fuel map look like what you actually want is useless and you will not benefit from it.
Old Mar 1, 2013 | 07:01 AM
Tekniq's Avatar
The car should still start. I went from stock to 1000cc high Z and the car started up fine. It idled rich and wouldnt rev past 2k rpm. But the car should still start, which is what the question was.
Old Mar 1, 2013 | 10:22 AM
steven121's Avatar
If your using the tephra I personally suggest it i was running lean with my bigger injectors, after 8 psi it leans to 13.5 and stays there, before i was at stoich, so i let off the throttle. With the stock injectors it should be fine
Old Mar 1, 2013 | 05:19 PM
bryonboals's Avatar
Thanks for all the input
Old Mar 1, 2013 | 06:07 PM
msrevo's Avatar
i wouldn't install the injectors until its time to tune
Old Mar 1, 2013 | 08:18 PM
ReaperX's Avatar
I would say there is an issue with latencies. Did you log battery voltage during the pull? A switch in injectors would have no impact on the maf scaling. Changing the maf scaling would be a bandaid fix for an issue with injector scaling and latencies.
Old Mar 3, 2013 | 11:32 AM
steven121's Avatar
Check out the thread I post about my ptes 1000cc
Old Mar 3, 2013 | 12:54 PM
ReaperX's Avatar
Link it and I will.
Old Mar 3, 2013 | 01:35 PM
Moready's Avatar
I'd say get a tune IMO.
Old Mar 3, 2013 | 07:25 PM
hiboost2.0's Avatar
Link it and I will.
Because I was curious. I think this is the one Steven was talking about.
https://www.evolutionm.net/forums/ev...rom-issue.html
