Injector or rom issue?
Old Mar 3, 2013 | 11:38 AM
steven121's Avatar
Before with the stock injectors I was running the tephra rom with the old defitinition file at 26psi maxing out the injectors
Now I'm using the pte 1000cc and my tephra rom seems to be the issue I guess "this is when I downloaded the new XML file for the categories on there are separated. And it seems like they lean out to stoich
Now I'm using my old stock rom and modified the loads and it runs like a charm at 18psi didnt increase boost yet but there are no leaks in the system
Anyone having trouble like this
Old Mar 3, 2013 | 11:48 AM
Hendrixmx's Avatar
What are your scaling and latency settings?
Old Mar 3, 2013 | 12:17 PM
steven121's Avatar
when I did this both trims were arond -.50
scaling 914
4.687 - 3.504
7.031 - 2.208
9.375 - 1.464
11.71 - 1.128
14.06 - 0.864
16.40 - 0.720
18.67 - 0.600
Old Mar 4, 2013 | 09:28 AM
steven121's Avatar
Any ideas?
Old Mar 4, 2013 | 09:56 AM
chamelieon's Avatar
check your "MAX AFR vs coolant temp" in main map fuel settings.
make sure your 171-181 temp column has a rich enough # in there. had a similiar issue leaning out and that number was high! error on my part, dont think the stock roms come with it high.
Old Mar 4, 2013 | 11:03 AM
steven121's Avatar
I put it at 40 because of the merlin evo guide thanks ill try it
BillSpec
Apr 7, 2014 09:19 PM
steven121
Feb 9, 2013 08:16 PM
jhoganusaf
Jan 17, 2013 09:53 AM
nikos_paps
Dec 23, 2012 11:02 AM
steven121
Sep 12, 2012 06:46 PM
