Still having problems
Old Mar 3, 2013 | 11:43 AM
Fishd0's Avatar
Ive fixed the vaccum lines and replaced the plugs. No longer hitting fuel cut but it still doesnt have the power it should. I think its running of the wastegate only. How can i check if the oem boost solenoid is working properly?
Old Mar 3, 2013 | 11:49 AM
barneyb's Avatar
Boost gauge
Old Mar 3, 2013 | 11:52 AM
Hendrixmx's Avatar
When in the rpm range does your boost start to build? Whats your max boost setting? Does it get there everytime? Same rpm range?
Old Mar 3, 2013 | 12:06 PM
Fishd0's Avatar
It builds around 2600the rpm. I dont have a gauge so i dont max boost pressure. Its on stock turbo, hard piping with k&n intake turbo back exhaust 720 injectors. It has random wires like there use to have a tuner or boost controller
Old Mar 3, 2013 | 12:21 PM
Hendrixmx's Avatar
You should definitely invest in a boost gauge, it's good to have so you can monitor the numbers, and know if something is wrong. If the numbers are off from normal, ie when boost builds, max boost pressure, vacumn readings give you alot of clues to what your car is doing, etc..
Old Mar 3, 2013 | 12:31 PM
Fishd0's Avatar
Ill order one but in the mean time any thing else i can do?
Old Mar 3, 2013 | 12:39 PM
Hendrixmx's Avatar
Do a boost leak test
Old Mar 3, 2013 | 02:39 PM
Fishd0's Avatar
Went out and got a boost gauge. Running max boost of 13 lbs.
Old Mar 3, 2013 | 02:55 PM
joshua_s's Avatar
It might be a good idea to even check your tune, if you are running 720cc injectors and there used to be a boost controller maybe you are either running to rich or lean if something from the original tune has changed.
Old Mar 3, 2013 | 02:59 PM
Fishd0's Avatar
I have get the data cord first to read it
Old Mar 3, 2013 | 03:22 PM
Fishd0's Avatar
Wat would cause the low boost and its not cause of a leak. Do i not have a vaccum line right or is it the tune?
Old Mar 3, 2013 | 03:24 PM
Fishd0's Avatar
If i run the wastegate strait to the solenoid alone the boost will skyrocket past 25 . But if i t the wastegate in with a line off the manifold like its supposed to be it only hits 13. I
Old Mar 3, 2013 | 03:28 PM
fastyouth1313's Avatar
Go straight from the j pipe to the waste gate. And tell us what boost you hit.
Old Mar 3, 2013 | 03:30 PM
Nothing is supposed to be T'ed if your on stock boost solenoid it goes from turbo j pipe, to boost controller then on the other hole on the boost controller to the waste gate actuator.
Old Mar 4, 2013 | 12:56 AM
Fishd0's Avatar
The diagram i went off of showed a line coming off the j pipe teeing with the wastegate to the controller then the top port goes to the intake off the turbo behind the maf
