Missing Bolt/Slight Oil Leak
Old Mar 4, 2013 | 01:20 PM
CAD EVO's Avatar
Was changing my oil and noticed the area to the right of my pan looked very greasy and there was some sort of leak. Car has been sitting since December.
Is there a bolt missing?
Had the clutch replaced 10,000 miles ago. I have never noticed a spot or leak on the floor, this seems to be a slight leak.
Is this something I should be worried about? Car runs great, never saw signs of this leak until now.
Old Mar 4, 2013 | 01:27 PM
06RedRalli's Avatar
Need to find a bolt to replace it. Def don't want to be leaking that fluid. If I'm correct that's the transfer case and loosing fluid from that can be a 1k dollar mistake, for the price of a rebuild. Or if it's leaking trans fluid, that can be a big mistake as well, could run low on fluid causing either bearing failure which could result in breaking gears/shifter forks...
Old Mar 4, 2013 | 01:38 PM
CAD EVO's Avatar
So there is definitely supposed to be a bolt there? It makes sense since it is threaded. Can someone possibly just check under there car for me
Thanks
mdsevo06's Avatar
That looks like it's migrating down from the back of the block/head, not with the flow of air towards the rear of the transfer case. I would check the rear of the block/head. Did you do a one by one head stud replacment in the past?
Old Mar 4, 2013 | 01:40 PM
CAD EVO's Avatar
The head studs were installed by mojo motorports in LI using the 1X1 method. I will definitely check the back of block and head.
Old Mar 4, 2013 | 01:45 PM
mdsevo06's Avatar
That's what it looks like, and sometimes they last for 5K, sometimes for 50K, but it looks like it's migrating down, not horizontal and forward from the transfer case.
Old Mar 4, 2013 | 01:53 PM
CAD EVO's Avatar
Funny that you say 50k because it was almost exactly 50k miles ago. If this is the case, looks like Ill need a new head gasket and studs.
By any chance do you know if I am in fact missing a bolt in the first picture?
Old Mar 4, 2013 | 01:59 PM
mdsevo06's Avatar
I'm not with my car right now, at work, but I'm sure others could chime in. With the close proximity of the two bolts, I wouldn't think that's a missing bolt for seal purpose.
Old Mar 4, 2013 | 02:09 PM
mdsevo06's Avatar
Just checked, I don't have that bolt there as well, must be an alternative mounting point. If this is in deed your head studs leaking, you might as well do a Valve Job with a Head Up Gasket kit, and depending on your time spent on the Timing Belt, might do this as well. There's a couple Heater Hoses from the firewall to the back of the block, this is a good time to replace those as well, they like to burst with age. Your looking at about 3K, I just did this four month ago.
Old Mar 4, 2013 | 02:16 PM
CAD EVO's Avatar
Hey thanks alot man..youve been very helpfull
Old Mar 4, 2013 | 02:28 PM
mdsevo06's Avatar
Use CAD jockeys have to stick together.
saabskijc
Jul 24, 2015 04:54 PM
the_evodude
For Sale - Wheels / Tires
Jun 6, 2013 09:29 AM
BCspeed34
Apr 25, 2013 05:15 PM
ExtremeDSM
101
Jun 15, 2012 03:03 PM
John@MooreAuto
35
Mar 12, 2012 08:10 AM
