losing power
Old Mar 12, 2013 | 08:55 PM
bryonboals's Avatar
losing power
So, I just rebuilt my motor and when its cold the car normal but when it heats up it starts to spuder and feel like I am running on 2 cylinder. The car sat for about 5 months is it the gas?
Old Mar 12, 2013 | 08:59 PM
BEKevo's Avatar
Sounds ignition related.. Check the plugs & coils. Provide more information and we can help you out a little better
Old Mar 13, 2013 | 06:44 PM
Kian's Avatar
it sat 5 months before the rebuild? is it throwing a code?
Bad gas, dirty injectors, if you just rebuilt it you most likely left a coil loose
most likely its an operator malfunction
Old Mar 13, 2013 | 07:51 PM
Awdtsier's Avatar
Definitely check all connections and do a tuneup. Like BEKevo said, sounds ingintion related. Good luck!
Old Mar 14, 2013 | 10:47 PM
bryonboals's Avatar
I am getting a vague code that says it ignition, fuel injector, mass vacuum leak and miss fire on #2 cylinder. My next step is to change over fuel injector since I already have some, they are 750 which are a little bigger then stock, to see if it that.
Old Mar 15, 2013 | 04:17 AM
Kian's Avatar
If you have a power probe you can pull the rail with the injectors and apply power at the plug to see if they spray.
Old Mar 16, 2013 | 08:53 AM
bryonboals's Avatar
There is also a map sensor code. It only run like crap or miss fires when it warms up
Old Mar 17, 2013 | 05:24 PM
bryonboals's Avatar
it was coil
getek20
Jan 30, 2019 12:19 PM
Llew
Jul 17, 2015 02:34 PM
wchan3
Lancer Engine Tech
May 19, 2014 05:27 PM
clubEVO93
Apr 2, 2013 11:29 AM
extrachrispy07
Mar 20, 2013 12:22 PM
