Good suspension upgrades
Old Mar 14, 2013 | 10:27 PM
Viegasjuice's Avatar
05 evo still on stock suspension. Can anyone recommend a good suspension upgrade? Coilovers/struts
Old Mar 14, 2013 | 10:33 PM
RallyBud's Avatar
Used Bilstein struts and Swift or Gtworx springs. Rear sway bar and rear diif mod are also popular choices. Good tires also help a tad...
Old Mar 14, 2013 | 10:45 PM
Can you further explain this rear diff modd?
Old Mar 14, 2013 | 11:02 PM
RallyBud's Avatar
I had elbow surgery a couple days ago and typing with one hand is slow...but here is a link. The first post has a few links as well. https://www.evolutionm.net/forums/ev...ound-here.html
Bottom line is the USDM models got screwed by the way the plates are arranged. There is an easy fix though. I'm not the most mechanically inclined but did the mod in a day.
Old Mar 14, 2013 | 11:28 PM
Awesome, thank you. Sorry about the arm, and I hate to bug but...is the improvement noticeable?
Old Mar 15, 2013 | 10:51 AM
RallyBud's Avatar
Yes, it is noticeable. The car drives neutral with a bit of oversteer tendencies. It feels like the rear outside wheel pushes through the corners when getting back on the throttle. I have Diaqueen diff fluid in it now has friction modifiers in it so I am not seeing its full potential. I am going to switch to something without the friction modifiers soon just to test it out.
Here is a quick video I did the day I rearranged the plates....post 295
https://www.evolutionm.net/forums/ev...actory-15.html
Old Mar 15, 2013 | 12:59 PM
Cudi's Avatar
Rear diff work is $$$. Get a rear swar bar before all if you desire more oversteer without going broke
Old Mar 15, 2013 | 01:02 PM
DisgustipatedM3's Avatar
Rear diff work is $450 from TRE or $180 if you do the 12 plates yourself from Weir. That's dirt cheap for either one.
Old Mar 15, 2013 | 01:36 PM
Thore's Avatar
Driver mod + tires.
When your friends are able to out drive you with less mods and better tires, then you know what needs to be improved (in my case). Although, with that said, a set of good quality springs couldn't hurt.
I happen to have a set of Swift sports I'm looking to sell.
Old Mar 15, 2013 | 02:56 PM
RallyBud's Avatar
I am not mechanically inclined and re-stacking the plates cost only cost a bottle of rear diff fluid. But, you need tools and space.
Originally Posted by Thore
Driver mod + tires.
Old Mar 15, 2013 | 09:29 PM
EvoJoe21's Avatar
whiteline bump steer correction kit is a must
edit:if you're doing coilovers you should do this
Old Mar 15, 2013 | 10:52 PM
RallyBud's Avatar
What about with springs?
Old Mar 15, 2013 | 11:37 PM
EvoJoe21's Avatar
its a solid upgrade if you're lowering the ride height at all. read this and it will explain(also a great thread if you do not have access to a shop press):
https://www.evolutionm.net/forums/ev...hop-press.html
if you are just going for looks and don't car about handling then forget the bump steer kit, you can worry about that later. all depends on the the OP is trying to do
Old Mar 16, 2013 | 12:03 AM
Totally 100% going for improved handling. I wouldnt spend that kinda money for looks.
Llew
May 30, 2016 10:52 AM
hiwords
May 29, 2015 08:25 AM
Rvargas GTS
11
Apr 21, 2013 12:10 PM
Token
Aug 29, 2011 10:39 PM
russya
Sep 12, 2004 08:55 PM
