IC sprayer clicking?
Old Mar 15, 2013 | 01:43 PM
xXANCHORMONXx's Avatar
I may just delete it but it just stopped working and it now makes a clicking noise in the trunk area?
I don't know why anything in the trunk would click.
Any ideas?
Old Mar 15, 2013 | 02:26 PM
Ev0ikon's Avatar
Are you saying that you hear clicking noise in the trunk area when you press the button to spray the intercooler?
Old Mar 15, 2013 | 02:39 PM
Yeah when I hit manual it sounds like breaker going on and off
Old Mar 15, 2013 | 02:46 PM
barneyb's Avatar
Nothing in the trunk area is connecting to the sprayer including wiring.
Old Mar 15, 2013 | 02:51 PM
Ev0ikon's Avatar
Hmmm. Did you modify that sprayer from stock in any way? All the IC sprayer stuffs (including relay and pump) are in the front of the car.
Sounds like you got an electrical issue to trace.
Old Mar 15, 2013 | 04:39 PM
Mhm. I haven't touched anything.
I guess it's time for it to go lol
Old Aug 6, 2016 | 04:40 PM
Ude Lose's Avatar
Having this same problem...
Any ideas???
Old Aug 6, 2016 | 06:27 PM
zbestevors's Avatar
yeah should not hear noise in the trunk. your ic sprayer is under the hood. have someone turn it on and you listen and pinpoint the sound you hear. as for your ic sprayer you may check to see if its clogged you can remove it and check. you can apply 12volts and ground to it with a vacuum line connected to it with the other end inside a cup of water and see if it pumps. if it don't pump replace it
Old Aug 9, 2016 | 02:37 PM
barneyb's Avatar
https://www.evolutionm.net/forums/ev...s-how-fix.html
Old Aug 10, 2016 | 07:04 PM
Ude Lose's Avatar
There is actually some kind of junction box with 3 hoses coming off it under the trunk on the drivers side.
I was under the car and a friend was activating the manual ic sprayer switch and it was just clicking.
So i removed it and it lools like a diaphram driven device. It is really strange and im probably going to have a hard time finding one pre owned and have to order it from the dealer.
I will post pics here once i have a chance...
Old Aug 10, 2016 | 07:21 PM
Ude Lose's Avatar
The device making the clicking noise was the ..... evaporator emission ventilation solenoid..
What does that have to do with the intercooler sprayer and why does it click when i push the manual button on the ic sprayer button.
Old Aug 14, 2016 | 12:08 PM
Ude Lose's Avatar
Bump for help
Old Aug 14, 2016 | 12:21 PM
barneyb's Avatar
eddy5201314
Dec 27, 2016 08:00 PM
Devesh Budhram
Dec 23, 2016 02:00 PM
mklepper
Aug 22, 2016 01:27 PM
mklepper
Aug 17, 2016 04:13 PM
Ralliart-D
Mar 21, 2016 10:13 PM
