New fuel pump
Old Mar 20, 2013 | 12:24 PM
Evo_Vinh's Avatar
New fuel pump
Hey guys just installed a new walbro 255 lhp pump from my oem. At first the car shut off after 5 minutes of driving. Then turned on fine. Now when I'm at a stop sometimes it drops relatively low below 1000rpm and jumps back up and fluctuates again... Is it a bad pump? Or does it need sometime to adjust.. Thanks
Old Mar 20, 2013 | 12:41 PM
BEKevo's Avatar
Did you install injectors at the same time? If yes, you need a tune. If you just installed the fuel pump, it sounds like you have low fuel pressure or something. Did you check the vacuum lines on the FPR and re-check all your connections?
Also do you have a wideband AFR gauge?
Old Mar 20, 2013 | 01:31 PM
Evo_Vinh's Avatar
Nope only the fuel pump... Plan to do injectors though before I go e85 though. And no I don't have a wideband gauge.. How can I check manually..
DuBBzEvo27
Sep 4, 2014 12:15 PM
evodrivesme
Aug 26, 2014 12:14 PM
boostedrb
Jul 2, 2014 04:43 PM
mattp_160
Jun 27, 2013 10:09 AM
Tmosser
39
Sep 21, 2012 01:35 PM
