Need advice on upgrade
Old Feb 17, 2004 | 07:52 AM
aaaaa5star's Avatar
Arrow Need advice on upgrade
Has anyone tried these i have been looking for upgraded rotors for my evo8 they look awesome http://www.brakeworld.com/catalog.as...02C&invidtype= what should i go with drilled, slotted, drilled & slotted???
i am not racing my car but do drive it very hard on the road
Old Feb 17, 2004 | 08:13 AM
4-BNGR's Avatar
Just get some better brake pads...
Old Feb 17, 2004 | 08:53 AM
memo3's Avatar
If you really wanna upgrade ur discs then I would go with drilled and slotted for better performance...
Old Feb 17, 2004 | 11:19 AM
aaaaa5star's Avatar
What do you guys use for pads are the Ferodos good?
Old Feb 17, 2004 | 11:21 AM
Guack007's Avatar
Yes, but kinda expensive.
Anyone know how the life on those is?
How good are the EBC Greenstuff/redstuff pads??
Old Feb 17, 2004 | 11:53 AM
Want to Evo's Avatar
I would stay away from cross drilled rotors on a street car. They crack very easily and must be replaced more often than a normal rotor. I had cross drilled Brembo's on my Supra and i cracked all 4 of them.
Old Feb 19, 2004 | 05:10 PM
chickenbrest's Avatar
I got the Panther XP 1108 pads from Carbotech.
http://carbotecheng.com/main.htm
They are full racing pads but they make some street/race pads as well. I called them and they were very knowledgable and helpful. I have not put them on my car yet, but plan to in a week or two.
Old Feb 19, 2004 | 05:12 PM
As for upgrading the brakes -- I kept the same rotors for now. Got the air cooling brake guides from Mitsubishi, the carbotech brake pads I mentioned above, stainless steel braided brake lines from goodridge, and Motul RBF 600 brake fluid.
Old Feb 19, 2004 | 09:54 PM
BenM's Avatar
Can you tell a difference in stopping power?? i always figured that if the brakes are strong enough to make the wheel stop spinning (to the point where ABS starts doing its thing) that the brakes were good enough... i'm probably wrong... can you explain?
Also, my brakes squeek when braking at low MPH. anyone else? what can i do to make this stop?
Thanks
Ben
Old Feb 19, 2004 | 10:03 PM
Thanks
Ben
About the brakes squeeking. There is pretty much nothing you can do, its just the nature of performance brakes.
Old Feb 19, 2004 | 10:23 PM
BenM's Avatar
so your stock evo does it too?? i only have about 4500 miles on mine. should that make a diff?
Ben
Old Feb 19, 2004 | 10:24 PM
BenM's Avatar
by the way... this is off topic but HOW MUCH LONGER AM I GOING TO BE A NEWBIE?!?!?! ok, that's all...
Ben
