Sulfur smell and smoke coming from battery
So today I took the evo out for the 1st time in about 7 months and for most of that time the battery was on a battery tender. Well I had installed the battery about a month ago but I didn't drive the car until today. So I went to start the car and that battery was dead which was no surprise since I have the ams small battery kit. I took my jumper pack out of my car and attach the leads to te battery and it started no problem. I went to the mall with my girlfriend and the battery was dead again so I did the exact small thing and jumped it. It started again and all was fine so we took a nice drive to the beach and back which probably took about 2 1/2 hours and when I parked my car in the garage we noticed there was a weird sulfur like smell coming from it. I figured it was something burning from te exhaust since its been sitting for so long but I poped the hood and all I saw was smoke coming from the battery terminal and it smelled horribly of sulfur. I took the red positive cover off and it was soaked in either water or some clear liquid. The battery wast burning hot but it was hot to the touch. All the connections and wires seemed fine but the battery seems like junk. Does anyone know what battery I can use to replace the small battery that comes with the ams kit. I'd like to order one ASAP so I can drive my car again. Also could the alternator be the culprit here as well? The batter is about 4 years old. I won't be driving the car or even messing with the battery until I get a new one since from what I read whatever is coming from the battery is hydrogen sulphide and its extremely explosive.
I just ordered a new battery. I ended up getting the odyssey pc680. I took a look at my old battery and the sides swelled up a good amount. I'll have to check the voltage the alternator is putting out once I get the new battery. Hopefully he alternator is good but of not ill just change it out along with the serpentine belt since I would have to remove it anyway.
If the battery was that dead and you drove for 2 1/2 hrs the alternator could possibly have cooked the battery hence the sulfur smell and battery acid everywhere. Obviously that battery is no good now, replacing it was smart. You have the right idea checking the alternator but make sure you check amperage along with voltage. Sounds like the battery was just bad but double check everything.
The battery was about 4-5 years old. I had it out for the car on a battery tender for about 7 months but then it just sat in the car connected for about 5 weeks and it was completely dead when I went to start it. I haven't had the time yet but I'll probably put the new battery in tomorrow.
GreyLancerES
Lancer Troubleshooting
14
Nov 13, 2014 08:32 AM
MaxandanEvo
Sep 11, 2012 04:27 PM
