Evo 8 Mystery Noise Please Help!!!!
Old May 8, 2013 | 08:12 PM
street2dirt's Avatar
My evo 8 is making a very annoying grinding noise, in first gear from 2k RPM all way to 3.5K RPM with the clutch all the way out. It also does it when decelerating and leaving it in a gear. It comes from the drivers side of car. The car just got a new ACT racing clutch 900 miles ago, and I broke in the clutch for 500 miles. No launches on this new clutch. I know racing ACT clutches are loud, but this doesn't sound right. I brought it back to the shop and had two of the guys from the shop drive it, and one said its not the clutch just something rattling around in the engine bay, the other guy who drove it said he didn't hear a thing. I went home zip tided every thing down in the engine bay and it still makes the noise. The car has 51,000 miles on it and has had all its servicing, the car also only makes 300AWHP. I made a video to show it, you can notice it if you turn up your volume, listen for 1st gear. Please let me know what you think.
http://www.youtube.com/watch?v=YCfaA...ature=youtu.be
Old May 8, 2013 | 09:23 PM
ReidFletcher's Avatar
What fluid was used in the trans after the clutch was installed?
Old May 8, 2013 | 09:30 PM
Not sure, it was done at KT motoring, i could find out tomorrow... could that be a factor?
Old May 8, 2013 | 09:40 PM
Its definitely drivetrain noise, and technically the only variable could be fluid. Yes the clutch is new but single plate clutches don't normally make a bunch of noise and if it were the clutch making the noise, it would make the noise in every gear in a specific range.
Old May 8, 2013 | 10:00 PM
ok ill definitely check out the fluid, but does this noise mean the clutch is bad to drive?
Old May 8, 2013 | 11:53 PM
AnabolicEVO's Avatar
That is very odd. At first I thought maybe the shifter linkage but read more and knew it wasn't that. Definitely find out about the trans fluid used. I really wanna know what this issue is. Good luck man.
Old May 9, 2013 | 07:56 AM
ill do a search to learn more, but what trans fluid do u guys suggest...
Old May 9, 2013 | 04:46 PM
called the shop and they used redline mt85.... does that lead to any problems????
Old May 9, 2013 | 07:49 PM
Do you have a 6spd or 5spd? 75w85 is the oem weight fluid for a 6spd. If you have a 5spd; yesterday if possible change to the redline cocktail(2qts of MT-90 and 1 qt of MTL). Also it's worth asking what fluid they used in your tcase. If its anything but Mitsubishi diaqueen then you should change that aswell pretty soon. It's debatable to an extent but diaqueen is the absolutely only fluid that should be in the tcase.
Old May 12, 2013 | 11:02 AM
its the 5 speed
Old May 12, 2013 | 11:10 AM
evobros's Avatar
Just take it back to khiem!!
Old May 12, 2013 | 02:34 PM
sunday morning update. had to drive car this morning, letting it sit for a couple of days. 80% of noise has gone away. Car is going in to RRE for cams and a dual map for e85, so i am going to have the shop do a service and change all the fluids. Ill keep you guys updated
Old May 13, 2013 | 09:27 AM
superkizuna's Avatar
won't the clutch only make noise when you let off the gas if it is clutch related rattling? if you pump in neutral it shouldn't do anything right?
silver_evo
28
Aug 28, 2019 06:53 AM
butte
Mar 26, 2015 10:35 PM
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
omarymee
23
Nov 19, 2013 06:43 AM
deeman101
60
Jul 18, 2013 01:29 PM
