Tephra issues
Old May 10, 2013 | 10:08 AM
Viegasjuice's Avatar
Tephra issues
Since my tuner switched me over to tephra, my idle is rough(sometimes cuts off), also now stays lean during boost instead of normal. Car cant idle with ac on either.
Old May 10, 2013 | 10:17 AM
Robdeep3's Avatar
Sounds like you need to talk to your tuner, if they messed something up they should be able to fix it
Old May 11, 2013 | 05:17 AM
evo8426's Avatar
That is not a Tephra issue, that is the tune itself unless something has changed with the car.
Old May 11, 2013 | 11:58 AM
awdordie's Avatar
Sounds to me like they forgot to copy some of the tables over. Or you could have a vacuum leak that has developed aand causing your problems as well.
Old May 11, 2013 | 12:01 PM
joseph143's Avatar
There are a few tables that can be tweaked to adjust all of that... Talk to your tuner
Old May 15, 2013 | 08:37 PM
evox4b11turbo's Avatar
Definitely talk to your tuner.. My car did the same thing when i first got a dual map tune.. It just didnt feel right so after taking it to him a few times and having the same problems i finally decided to take it to a different tuner and it resolved alot of my problems.
Old May 15, 2013 | 09:22 PM
PureDrivePerformance's Avatar
+1
I've tuned this numerous times. PM me if I can help.
Old May 16, 2013 | 12:12 AM
steven121's Avatar
Tune is your issue if you need help pm me
AKW89
Apr 15, 2013 04:23 PM
babaz7
Nov 17, 2012 11:42 PM
scandinavian
Sep 15, 2012 03:15 PM
motocooney
Nov 12, 2010 12:53 PM
Jim in Tucson
E85 / Ethanol
14
Apr 11, 2010 08:36 PM
