Engine shuts off?
Old May 15, 2013 | 02:23 PM
gen257's Avatar
Engine shuts off?
The other day i was driving my car and then suddenly when i was approaching a red light i clutched in and braked softly my engine would shut off.. i was wondering what could be the issue. I asked around and they said something about the EFC and to adjust the fuel consumption. something to do with the DEFI controller? oil pressure drops btw.
Old May 15, 2013 | 02:26 PM
Ev0ikon's Avatar
Post all the info you know about the car. Any modification?
Old May 15, 2013 | 09:17 PM
gen257's Avatar
Heres the list
280 FP Cams
APR head studs
Titanium valve springs and retainers
Exedy Twin Plate Clutch
AMS Clutch Lines Upper/Lower
Nisei Mini Battery Kit
GM 3 Port boost Solonoid
Odyssey Mini Battery
Nisei lower intercooler piping.
Nisei upper intercooler piping.
ARC intake box
1000cc R/C injectors
Walboro 255 fuel pump
Tanabe 2.75" down pipe
Megan test pip
RSR catback exhaust
Synapse blow off valve
Suspension and Brakes:
Tein MONO FLEX with Eelectronic Dampening Force Controller (EDFC)
24mm Cusco Rear sway bar
Cusco Type A Underbrace
Cusco Type B Underbrace
Stoptech Lines
Stoptech Slotted Rotors
Project Mu Pads
Wheels and Tires:
5zigen FNORIC 17x8.5 in black
Brand new tires 245x45x40
Exterior:
OEM Mitzubishi Window Visors
HKS Radiator Cap
HKS Oil Cap
Deevo Radiator Mounts
Cobb exhaust manifold heat shield
Ralliart Radiator Shroud
5% tint all around
6k 55watt HID with ballast
JDM Rear bumper
Front fender extenders
Carbon Fiber Ralliart replica front lip
Interior:
Defi 60mm Boost Gauge
Defi 60mm EGT Gauge
Defi 60mm Oil pressure Gauge
Defi Controller
Zetronix LCD for AFR
Gruppe-s Radio Relocation Ckit
Gruppe-S 60mm Gauge holder
Greddy Counter weight Shift Nob
Pioneer CD player with USB adapter
Alpine Type-S 6.5 Coaxial Speakers
Alpine 250watt x 4 Amp
8" Rockford Fosgate Sub with low profile box
Old May 16, 2013 | 07:37 AM
Ev0ikon's Avatar
What is your oil pressure at cruise and at idle?
Old May 16, 2013 | 08:12 AM
gen257's Avatar
It is around 20 at idle and 50/60 at cruise
Old May 16, 2013 | 08:33 AM
Ev0ikon's Avatar
That's good pressure then.
Is your car still doing this constantly?
Can you post any log? Long/Short Term Fuel Trim and Throttle Position sensor?
Old May 16, 2013 | 01:01 PM
gen257's Avatar
mm the engine hasnt shut off again since yesterday... but i only drove it for a short distance, ill see if i can get some logs.. it seems okay after i adjusted the DEFI controller(it was set to all off for some reason instead of 4 cylinders). i did just buy this car like a few weeks ago so im not familar with the Zetronix LCD for AFR, which there is a blue button on the right side which i wonder what it does...
Old May 18, 2013 | 06:38 PM
MileHighX's Avatar
Does it start right back up with no issues at all??? Or do you have to crank it a few times?
Old May 18, 2013 | 08:56 PM
gen257's Avatar
Well that day when it shut off i just turn the key to turn it back on
3000GT-GTO
Mar 20, 2012 07:23 PM
EVO4-6
20
Nov 7, 2011 10:39 PM
shmaa
11
Jan 23, 2007 08:26 PM
Derek888
15
Nov 28, 2005 12:04 AM
