Filling fuel tank=better tranny shifting?
Old May 26, 2013 | 10:10 AM
Jonnysc14's Avatar
so I have an 04 gsr and was wondering if it's common that the tranny shifts much smoother when you fill your gas tank? I notice it does in my car for like the first 1/4 tank, then after it shifts a bit notchy. What causes this? Injectors, fuel pump, fuel pressure? Or would I need to upgrade any of the following. Motor is completely stock with only a Spoolin Up cop kit and Works drop in air filter.
Old May 26, 2013 | 10:25 AM
Czarcasm's Avatar
LOL what?
Old May 26, 2013 | 10:36 AM
adriano_917's Avatar
Not related its in your head.
Old May 26, 2013 | 11:03 AM
ace004's Avatar
I would go on to wonder that by the time he heads to the gas station his tranny fluids not cold so it shifts better? But no, nothing is related to the other.
Old May 26, 2013 | 11:35 AM
Jonnysc14's Avatar
I mean this could be but its a huge difference in shifting every time I fill up its like I don't have to try shifting and its great but later it gets notchy shifting around 3k rpm. This would happen on stock clutch and still does now on a broken in comp stage 2 clutch. Maybe I could be crazy but its an every time type thing.
Old May 26, 2013 | 12:25 PM
Jimmy Javelin's Avatar
LOL, dude its in your head.
Only thing I've experienced that affects it from being notchy to smooth/loose would be temperature.
Higher temperatures ncreases the fluidity of the liquids, I.E similar to heating up cooking oil on a pan and watching the liquid become easier to move.
Old May 26, 2013 | 05:52 PM
MarkChamorro's Avatar
Lol. I assume the tranny is warmed up by the time you filled up
Old May 27, 2013 | 01:27 AM
CDHoff's Avatar
What if something in his tranny isn't sitting right and the extra weight of the fuel helps the car sit where it needs to be for the tranny to shift correctly. I know that sounds crazy but I'm just throwing it out there.
Old May 27, 2013 | 03:47 AM
misterevo8's Avatar
engine torque damper!
Old May 27, 2013 | 08:21 AM
Jonnysc14's Avatar
I was also thinking this might help
Old May 27, 2013 | 08:44 AM
Jonnysc14's Avatar
Fox Fader
Dec 9, 2016 03:26 PM
ElectricBlueIX
Oct 30, 2013 03:44 AM
Red06Evo
May 31, 2013 04:14 AM
neogen69
Apr 10, 2013 10:04 AM
evovin
Jan 8, 2013 10:49 PM
