Double Pumper troubleshooting
Old May 29, 2013 | 05:06 PM
Macaroni's Avatar
Originally Posted by tiggeryellow1
Bro did you check out the past thead link from the above message? If not here it is again.
Yes I clicked the link. I'm not asking for help I'm just stating that I have the same problem and will figure it out once I get the time
Old May 29, 2013 | 05:30 PM
uvambo's Avatar
definitely a known problem with the buscher DP, mine does it too. One if not both of your bulkheads are leaking, Its easy to check. take the cover off clean the top of the pump body and fill your tank, you will see it start to pool up under one or both bulkheads. You need to find the leaky guy, pull it all apart make sure its tightened or get some kind of gasket in there to stop it.
Old May 29, 2013 | 06:10 PM
mitsubeastlee's Avatar
I still have not contacted buschur about it the second time around ive had it in for 1 week, so im just trying to see if it is gonna keep doing a drop here or there. Buschur took it back the first time and improved the leak and at first I thought I was 100% dry but when I rub my finger around the fitting by the washer I get 1-2 drops, no pooling no wet sender just a drop. Im trying to figure out if it means enough to pull it for the third time because it is such a pain and I didnt want to replace the fuel clamps and tighten the fittings well...because I feel like I paid for something that should work 100% not 99%. Overall i do like the pump setup though, and I have yet to hook up the wiring for the second pump so who knows if that will leak crazy but I do not need the extra fuel yet from the second pump but I will know soon.
jrainwater
Mar 18, 2014 07:48 AM
rain jaydin
Jul 2, 2013 07:24 PM
bzzbee2
Jun 23, 2013 12:02 PM
Kidloco51
May 31, 2013 09:49 AM
fuzzychi
Jun 21, 2010 06:31 AM
