Double Pumper troubleshooting
After installing a DP setup, what would cause fuel to leak outside underneath the car ONLY when topping off the tank with fuel?
Are there any stock lines that need to be removed? I have one stock hard line under the car that is unused, so nothing is attached to it. Do I just cap it off? Remove it?
Let me know what other info you need to help.
Thanks for any help.
i left the hardline untouched. didnt cap it or anything.
It was when I installed it. Haven't had a chance to take a look yet but just trying to get some ideas on where to start. Car also threw a CEL related to the fuel system. I will post up the code to see if they're related, which most likely will be the case.
My double pumper leaked when I got it as well. Mine ended up being one of the bulkhead fittings(large silver fittings on top of housing where black lines connect) wasnt seated flat against the plastic. I had to pull the bulkhead fitting out and grind down on the plastic a bit. Then it sealed perfectly fine.
This was on a Buschur double pumper and only leaked when I filled the tank.
I also bought a BR double pumper. It leaked bad under the silver custom primary pump fitting. I sent it back to be fixed. Around 2.5 weeks later I get it back and it still ever so slightly leaks. This time around top of whasher instead of under. Before it was bad leak now it only gets a drop or two when feeling with finger. I need to let buschur know about this still but I've been driving on it cause its REALLY minor now vs before. I'm doing testing to see if it will go away as crazy as that might sound.
Took me a minute to locate it but maybe something in hear can help: https://www.evolutionm.net/forums/ve...r-leaking.html
Buschur did make it right in the end for me.
Glad to help bro. Man we need a better way to search thru past posts though... MODZ can I get a friggin search button please every other thread on this forum has one. Cheese and Rice
Thanks guys. It was a quick and simple fix. The bulkhead wasnt tight on the top of the assembly. I could see fuel drops around it. However, there was still probably a couple turns left on it. Just wasnt sure how tight I should go but I'm going to keep my eye on it now.
Looks like the plastic was already shaved down under the other two silver fittings.
And just for redundancy, the black gasket is in place and tightened down.
Thanks again!
Thanks again!
