Need help with timing.
Old May 29, 2013 | 11:37 AM
manthny18's Avatar
Hello. I took timing belt of cam gears because i need to take m head off. long story short i need to put belt back on. So do i need to check timing in the bottom or do i just aline the cam gears since it was only removed from the top. Your help is much appreciated thanks. Evo 9 btw
Old May 29, 2013 | 11:47 AM
heel2toe's Avatar
Unless you were able to keep tension on the belt I believe you will need to retime the entire thing.
When I pulled my head I ziptied the gears to the belt and kept the tension on it and I didnt have to retime the entire engine.
In your case it sounds like you completely removed the gears so I'd guess that you will need to redo it.
Old May 29, 2013 | 12:03 PM
manthny18's Avatar
yes your right i did remove the whole thing with out keeping belt tensioned. ive been looking for vids on how to time a evo with no luck.
Old May 29, 2013 | 12:20 PM
heel2toe's Avatar
Hmm I dont know of any videos but these two threads may help you out:
https://www.evolutionm.net/forums/ev...placement.html
https://www.evolutionm.net/forums/ev...-belt-how.html
Old May 29, 2013 | 01:14 PM
manthny18's Avatar
ill take a look at them. thanks btw
Old May 29, 2013 | 02:08 PM
manthny18's Avatar
Btw do i need to time my balance shaft belt even though it wasnt taken out?
Old May 29, 2013 | 02:16 PM
4RETECH's Avatar
Here is a link . post number 6 has a picture I attached.
https://www.evolutionm.net/forums/ev...ing-marks.html
Old May 29, 2013 | 03:37 PM
elhalisf's Avatar
no, it will not need to be redone.
Old May 30, 2013 | 06:08 AM
manthny18's Avatar
Thank you i was waiting for some1 to let me know about the balance shaft belt.
Old May 30, 2013 | 08:22 AM
lostsoulsevo's Avatar
your balance shaft sprocket needs to be aligned with timing marks along with the oil sprocket and crankshaft.
Old May 30, 2013 | 09:37 AM
cfdfireman1's Avatar
don't turn the crank with any of the valves open
Old May 30, 2013 | 02:55 PM
Lyzek01's Avatar
Keep in mind that their are two balance shafts, and the alignment marks are not always correct. Best thing to do is either folllow the vid or take off the down pipe and take off the bolt in the block.. Stick a long screwdriver and check it is centered correctly. IF NOT DONE CORRECT your engine will vibrate very harshly at 3000 rpm.
Old May 30, 2013 | 03:06 PM
dont need take off balance shaft inspection bolt. twist the oil sprocket clockwise of the timing mark and let go, if it returns back (counterclockwise) you're good. if not, turn the sprocket 360. and do the step again, it should return back to the mark
Old May 31, 2013 | 06:19 PM
CeeWhizzle's Avatar
You should have lined everything up before taking the belt off.. and like others have said - Zip tie the cams together with the belt on. Goodluck though.
tsitalon1
Jun 30, 2014 03:54 PM
speedster07
Jun 27, 2013 01:22 PM
OC
Apr 22, 2013 10:32 PM
ILuvJDM
59
Feb 19, 2013 03:56 PM
Johnboy1065
12
Jan 14, 2013 03:43 PM
