Injector size
Old Jun 1, 2013 | 01:27 PM
Andrewkbmx's Avatar
Injector size
Im doing this setup and Boostin Performance said either 1000cc or 1150cc anyone running a similar setup
Stock 8 motor
evo 9 turbo/ ported from what i was told havent torn into it yet to check
gsc 274/274
map beehive valve springs
walbro 255
e-85
speed density
Basically just going to be fun weather street car aiming for a safe 400whp
Just in between what size injectors to get, Thanks!
Old Jun 1, 2013 | 02:50 PM
EVONOT's Avatar
I made 375 with 680cc and had a good bit of room(didnt come close to maxing out injectors). But if you plan on hoing more poeer or e85 then go with the higher
Old Jun 1, 2013 | 11:59 PM
InfamousEvo's Avatar
Injector Dynamics 1000cc. IDCs will be pretty low even with the ethanol and you'll have more overhead in case you decide you want more power down the road. Anything less than that and they won't be able to flow enough.
Old Jun 2, 2013 | 11:52 AM
Andrewkbmx's Avatar
Fic 1150ccs are about $100 cheaper for more. I think I'm going to go that route. Compared to Id1000 for almost $500
Old Jun 2, 2013 | 12:31 PM
Viegasjuice's Avatar
ID apparantly flow better from what ive heard so its worth it.
spooldoodle
Sep 2, 2014 02:31 PM
NightHawk
May 24, 2014 09:25 PM
whotippedmycow
Jan 25, 2014 11:58 AM
2e0v0o3_8
Oct 15, 2013 06:18 PM
evoe85
21
Sep 13, 2012 08:32 PM
