Need Some Advice
Old Sep 2, 2014 | 01:58 PM
spooldoodle's Avatar
Need Some Advice
My car is dumping to much fuel! i got 1000cc injectors 274 cams stock turbo. when cars on the rpms go down and car almost stalls. but if i have the ac on sometimes car just shuts off. well the point im getting at is what can i do to make the car run better, i already got a tune and was thinking about getting ets large runner stock replacment, would that make a difference? and also wanting to get fp green turbo
Old Sep 2, 2014 | 02:20 PM
mkcolgan's Avatar
IMO I don't think adding performance mods to it will clear up your problem... Definitely an issue that needs to be addressed. Checked for vacuum/boost leaks?
Old Sep 2, 2014 | 02:27 PM
SilverShadow03's Avatar
Last thing you want to do is throw parts at your car hoping to fix your issue....
Have you contacted your tuner regarding this issue? Check for boost/vacuum leaks as mentioned above...
Get the FP Green & whatever other mods you need after fixing this issue.
Old Sep 2, 2014 | 02:31 PM
e_kobz's Avatar
Get a better tune
soderdna
34
Feb 19, 2016 12:19 PM
WickedIXMR
14
Sep 21, 2013 03:19 AM
Jesperswe
Aug 15, 2011 01:03 PM
mlee25
15
Apr 21, 2010 07:59 PM
SpEeD_dEmOn
24
May 3, 2009 10:04 PM
