Help! Help! Help!
Old Jun 5, 2013 | 08:33 PM
blackandredgts's Avatar
Help! Help! Help!
Hey guys as you guys might now I bought an Evo from auction not too long ago. I'm having issues trying to figure this **** out. I thought it was my Maf but it's not! I'm having a rough idle at like 1.4k, black smoke from exhaust and it is running rich *** hell. Also my boost solenoid is not hooked up at all yet and need help with figuring that out. Also if anyone is in the Chicago area and could stop by to help it would be greatly appreciated!! Thanks in advance and I hope to get this solved QUICK!
Old Jun 5, 2013 | 09:49 PM
llDemonll's Avatar
take the car to a shop. if you can't figure out hooking up the stock boost solenoid you probably shouldn't be doing the rest of the troubleshooting. that, or start reading and dont start the car until you understand what it's doing
Old Jun 5, 2013 | 10:36 PM
heavens turbo's Avatar
1.4k is not idle. could be a misfire. black smoke is usually unburnt fuel. like demon said, take it to a shop. you could start with plugs and wires, but anyone on here would be grasping at straws without more info, like tuning/stock, mods, things like that. good luck.
Old Jun 6, 2013 | 07:25 AM
the only reason we didnt know it was a boost solenoid was because we thought it connected to the stock airbox. and my uncle is a mechanic and fixes rebuilt cars for a living and works at a shop. Im just reaching out for help to see if anyone might know what this could be or had it happen to them. no need to say that basically im an idiot because i didnt figure out the boost solenoid. also i have a check engine light on if that helps the troubleshooting.....
Old Jun 6, 2013 | 07:31 AM
gsrboi80's Avatar
Your uncle is a mechanic and rebuilds cars. Would he not have an OBD II scanner to scan the vehicle? How would we know sitting behind a phone/computer
Old Jun 6, 2013 | 09:48 AM
aporambo's Avatar
Autozone/OReily's perform free OBD2 scans. Go there and tell them you are having issues with the car running and for them to check it out.
Often they can lead you to what might be causing it and give you a parts list to fix it. You don't have to necessarily buy the parts from them either.
Old Jun 7, 2013 | 04:21 AM
The has it at work but can't bring it home to use. And I wonder if they would let me take it home fr like 30 min and then bring it back? Thanks for the hints guys!
Old Jun 7, 2013 | 09:23 AM
llDemonll's Avatar
you have to leave your drivers license with them to check it out, so bring a friend
Old Jun 7, 2013 | 08:11 PM
Oh alright thanks guys! Also forgot to mention that the check engine light is on and the cara response is delayed by a few seconds too
Old Jun 8, 2013 | 05:43 AM
bjmauck's Avatar
That sounds like a mass air flow or throttle position sensor issue. Definitely get the code checked. Without that it's like a stab in the dark.
Old Jun 8, 2013 | 12:45 PM
cmspaz's Avatar
If you leave the store property with it, they'll need to actually rent it to you. You might not get caught if you dip quick and come right back, but they might be pretty pissed if they catch you.
That said, do a boost leak test, you could have some major air leaks in the charge piping and vacuum system causing it to idle high, and fixing those might clear up some of the other issues depending on what components those leaks affect.
You already know you're missing the vacuum lines and solenoid for the boost control, why not just loop a vacuum line from the boost source to the wastegate actuator and cap off the nipple on the intake for the time being, that'll run you at 12psi that you can at least use to test things.
Old Jun 9, 2013 | 07:01 AM
I do not believe it is the Maf since I got a new one and nothing changed. Unless its the plug and harness for te Maf which scares me and thanks for the advice guys getting the car scanned this week!
Old Jun 9, 2013 | 07:58 AM
cfdfireman1's Avatar
Where in Chicago are you located?
Old Jun 9, 2013 | 11:59 AM
Jeff park right by the Austin exit off the I 90
Old Jun 9, 2013 | 01:49 PM
You have PM
A3188
Midwest Region
Jul 30, 2014 12:58 PM
broderickgil
Apr 15, 2014 10:33 PM
giumela
For Sale - Wheels / Tires
Mar 9, 2014 10:09 AM
ragyan03
Midwest Region
10
Feb 7, 2013 12:23 PM
