Assembling turbo help
Old Jul 21, 2013 | 03:09 PM
doober's Avatar
Alright so recently I removed the hotside from my turbo to send out and now I am here putting it back together scratching my head. I see the set pin and the hole but just by hand pressing the two sides back together I cannot guarantee it's lined up. It is just sitting above and could be slightly off.
I threw the clamp back on hoping to pull it together so I could remove it and make sure it was lined up but it still looked to be above the pin. Also sounded like something was loose or making contact. How can I be sure I have it lined up? Is it ok to go by my guess and give it a whack with the mallet or what should I do?
Also does anyone have a spare cotter pin for the WG arm laying around? I can't seem to find mine or any for sale. Always the small things to set you back huh?
Old Jul 21, 2013 | 07:25 PM
slowsrt4:('s Avatar
I set the two pieces together and gave it a few hits with a rubber mallet and it went together well. For the cotter pin you should be able to find a similar one at an auto parts store or even lowes or home depot
Old Jul 21, 2013 | 07:48 PM
doober's Avatar
Sounds like I am over thinking it then. Thanks for the input.
I'm just going to steal the one off my other turbo at the time of the swap. I forgot about that option.
Old Jul 23, 2013 | 08:22 AM
doober's Avatar
Too much shaft play? You can hear contact so that is obviously too much correct right? I can only imagine what would happen once that thing got spinning and made contact.
Should I sent it in for a rebuild and who do you guys recommend for stock MHI rebuilds?
Old Jul 27, 2013 | 07:24 PM
Miasma987's Avatar
Journal bearing turbo's are quite simple to rebuild. You could probably order the kit and do it yourself, just take it apart and put back together in the opposite order. Be sure to mark the compressor nut and shaft where they are lined up before loosing so that it remains in balance when you put it back together.
Old Jul 28, 2013 | 05:02 AM
doober's Avatar
I was going to do that but I figured I'd just upgrade it and get it balanced. Seemed like the best option.
Old Jul 28, 2013 | 08:03 AM
impact blue's Avatar
if you have the time is it possible that you can day it or video day it with some help . also uhhhm also list where you get your parts from to rebuild.
Old Jul 29, 2013 | 06:44 AM
Miasma987's Avatar
Depending on the turbo you have you can either get rebuild kits from the supplier or some good ones on eBay if you look around.
There is a video of a guy rebuilding a 16g turbo on YouTube. I don't have the link but if you search turbo rebuild it will pop up.
Old Jul 29, 2013 | 07:12 PM
ChristianAPEX8's Avatar
^ Very wise choice.
Old Jul 29, 2013 | 07:48 PM
ExViTermini's Avatar
I actually have a kit for a stock 16g I picked up years ago. It came from gpopshop. I'll let it go for 50 shipped, complete kit /shamelessplug
Old Jul 29, 2013 | 10:26 PM
SmittyPNW's Avatar
As for a cotter pin, a bit of safety wire will do the trick or anything like that you may have laying around the garage.
Alchem1st
Mar 15, 2022 08:47 AM
cij911
139
Mar 19, 2021 04:19 AM
itsmeek
Apr 7, 2016 01:26 PM
Live4Redline
Lancer Engine Tech
Aug 15, 2012 11:38 PM
EvoCorp
18
Nov 9, 2010 09:42 PM
