Is the brake pedal height/sensitivity adjustable?
Old Aug 9, 2013 | 01:09 PM
bnr34rb26dett's Avatar
Exclamation Is the brake pedal height/sensitivity adjustable?
I recently removed brembos from the car for repainting.
But now that I have reinstalled the brakes and flushed fluid. the brake pedal seems to engage at lower level.
It feels nice and stiff once the pedal hits the engagement point but I feel that the pedal goes down too far to the floor.
Is there a way for me to adjust the brake pedal height so that I do not have this issue anymore?
Is it similar to how the clutch pedal can be adjusted?
thank you
Old Aug 9, 2013 | 01:12 PM
Raptord's Avatar
Does the pedal come back up if you pump it a few times? I'm guessing you just still have air in the lines.
Old Aug 9, 2013 | 01:15 PM
thanks for the quick reply
yes, the pedal comes back up all the way. I used an entire container of super blue......
Is this a sign that there are stil air in the system?
Would the brake fluid flush procedure the same as when im simply flushing it vs replacing the brake calipers?
thanks
Old Aug 9, 2013 | 01:29 PM
19DB794's Avatar
Same thing happened to me. I kept bleeding and bleeding. I went through 2 liters of regular brake fluid and 3 liters of the super blue fluid. I bought a motive power bleeder and just kept bleeding and make sure you have no leaks but my brakes feel exactly like yours. They're firm but the pedal goes lower than it used to. Did you put the pads back in their old spots? I didn't mark which pad went on the inside or outside of the caliper so I'm assuming that's why it doesn't feel the same and the pads have to rebed to the rotors.
Old Aug 9, 2013 | 02:13 PM
Raptord's Avatar
thanks
What I meant was; does the pedal become firmer if you pump it a few times?
Are you using the same pads as before?
And yes the procedure is the same.
Old Aug 9, 2013 | 02:46 PM
19DB794's Avatar
And also make sure your bleeding in the correct order
Old Aug 9, 2013 | 03:30 PM
same pads same location
i will check on the firmness
are you talking about this with car on or off?
hmmm it sounds similar to whats happening to me. pads are installed in the same location though..
i am following this order
http://www.joe250.com/cars/evo8/brak...dingorder1.JPG
Old Aug 9, 2013 | 03:33 PM
19DB794's Avatar
Did you rebuil the brakes after they were painted/powder coated?
Old Aug 9, 2013 | 03:44 PM
Raptord's Avatar
car on.
Old Aug 9, 2013 | 03:50 PM
nope. same brakes same pds. same location...
car on.
i will check on this.
Old Aug 9, 2013 | 04:16 PM
19DB794's Avatar
I'm talking about did you remove the brake pistons and replace the seals and dust boots?
Old Aug 9, 2013 | 04:34 PM
No rebuilds. Just repainting
I pumped the brakes with engine on and it does seem to get stiffer and bring up the pedal position higher. Does that mean I need to reflush it I'm assuming?
Old Aug 9, 2013 | 04:41 PM
19DB794's Avatar
My brakes do the same thing. I pump them once and theyre the way thy used to be but i bled the brakes 3-4 times and its the best I've been able to get them. If you rebleed them or figure out what's wrong with them let me know. Maybe I'll bleed it once more with the extra liter of brake fluid I bought.
Old Aug 9, 2013 | 04:43 PM
ak47po's Avatar
thank you
http://www.joe250.com/cars/evo8/brak...ebleeding.html
DuBBzEvo27
Jun 16, 2014 09:58 PM
inslowoutfast
Feb 25, 2014 07:01 AM
ambystom01
Lancer Tranny/Drivetrain Tech
11
Apr 21, 2010 03:34 PM
DRAG
13
Nov 22, 2008 12:54 PM
smokedmustang
51
Sep 20, 2006 05:30 PM
