Best Cams for the Money
Old Aug 22, 2013 | 09:03 AM
Mr Ralliart's Avatar
Originally Posted by boostedtres
The tomei and s1 cams provide a very linear power band most similar to stock, doesnt shift the power band to the right as dramatically, and "can" be run on stock valvetrain, i disagree that they are best for a mildly modded motor.
This is why they are best for a stock or mildly modded motor.
Don't underestimate how much they will move the power band to the right while basically losing nothing down low. I fitted TOMEI 260's and picked up an extra useable 1500 rpm, and it drives like stock.
If the O.P just wants an all top end motor that is operating above the range the engine designed to work best in, and a rumpity idle, then yes they are probably no good.
Old Aug 22, 2013 | 09:26 AM
SmurfZilla's Avatar
No such thing as a best cam, best cam for your setup would be more accurate. What are your goals?
Old Aug 22, 2013 | 09:11 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Do a forum search in the dyno results sub-forum for brands you are looking into buying and find similar set-ups to get an idea as to gains.
IIRC the GSC S2 generally had the best results when a lot of people started switching to them back in 2010.
Old Aug 22, 2013 | 09:53 PM
APEXR's Avatar
Realistic question? Agreed, see above. ^
On a side note, has anyone else noticed that the OP asked a "broad" question & never came back? Troll?
hutch959
10
Nov 25, 2016 05:35 PM
real fast
Aug 27, 2016 04:55 PM
boostedrb
18
Aug 2, 2012 02:22 PM
mission664
66
May 19, 2012 11:27 AM
sleeper04
Dec 20, 2010 12:17 PM
