need help
Old Sep 13, 2013 | 02:02 PM
tbaird58's Avatar
need help
i just bought my evo yesterday and the guy says the sunroof wont work, the motor turns but no movement, its not in the sealed postion and i want to know if there is a way to put it in the seal position until i can fix it, i dont want any water leaking into my car
Old Sep 13, 2013 | 02:27 PM
ctfpevoVIII's Avatar
I don't want to give you wrong info but most cars usually have some sort of panel by the sun roof controls where you can manually close the sun roof with a allen key. Did you look in your owners manual ?
Old Sep 13, 2013 | 02:34 PM
tbaird58's Avatar
the car didnt come with the owners manual :\
Old Sep 13, 2013 | 02:49 PM
tbaird58's Avatar
i can push the sunroof up and it will sit flush but i dont think it will stay that way with road vibrations
Old Sep 13, 2013 | 09:26 PM
iTzMe's Avatar
If it sits flush it shouldn't leak but you should buy the whole sunroof setup incase it's just not the motor
Old Sep 19, 2013 | 12:17 PM
DSMolition's Avatar
Its easy to fix and a common problem.
https://www.evolutionm.net/forums/ev...k-sunroof.html
Finish up by doing this.
https://www.evolutionm.net/forums/ev...ml#post8158403
Also if you use a more descriptive thread title you would have more reply’s.
Old Sep 20, 2013 | 06:57 PM
tbaird58's Avatar
omg thank you, i was about to go in blind tomorrow morning and hope that it didnt take all day, but now it looks like it will only take about 2-3 hours, thank you again ill update when its fixed
Old Oct 14, 2013 | 05:58 AM
DSMolition's Avatar
Any luck man?
Old Oct 17, 2013 | 11:38 AM
tbaird58's Avatar
yeah i got it all fixed, 2 of the 3 bolts came out of the motor and the 3rd bolt was super loose, so put some locktight on there and put everything back and now works like a charm, and my friend and i did the whole thing in about an hour, thanks for the help guys
stunna2o1
Jan 25, 2016 07:02 PM
iKENwin
Nov 30, 2015 06:15 AM
JTCB
Apr 8, 2015 02:46 PM
LGshow19
Jun 13, 2012 06:42 AM
specter61
Oct 11, 2011 03:57 PM
