Evo problem! help if you like.
Old Sep 22, 2013 | 06:40 PM
gkew's Avatar
So after abuot 20 minutes of driving on the highway then on to local on a 10 mph turn my car turns off, everything shuts down. I then turn the car on, it started then turns off, this happens for 3 attempts so I decided to pump a bit of gas and finally it stays on. Upon the car being on the RPM stumbles like crazy.. going up to 1000rpm then drops to 200 then goes back up so I decided to let the car idle for a bit in that state. After about 5 minutes, the car idles fine and everything was back to normal so then I decided to drive home. the car seems to drive fine now. Sometimes the car would stumble while driving, when I step the gas a bit, it would jerk lightly, the rpm wouldnt raise unless I floor it but it accelerates really slow and this happens randomly. The only way to get rid of this problem is when I pull aside and let the car idle 4-5 minutes then the symptoms would go away. I've checked the MAF sensor and it seems to be in tight. any clues to what the problem is?
Old Sep 23, 2013 | 08:13 AM
sujinX's Avatar
bad gas? did this JUST happen after a fill up or been sitting for a long amount of time?
Old Sep 23, 2013 | 08:20 AM
InoNothingMR's Avatar
Something sort of similar happened to me when I forgot to hook up the vacuum line to my intake after doing some work on it. Check and make sure everything is hooked up! Zip ties are your friend lol
Old Sep 23, 2013 | 07:04 PM
MRolla's Avatar
Sounds like your fuel pump on the way out
Old Sep 24, 2013 | 01:41 PM
gkew's Avatar
the car is driven everyday since its my DD and also thanks for the help, I will look into the matter and see whats going on thanks.
Old Sep 24, 2013 | 01:53 PM
ebadai98's Avatar
Sounds like a vacuum line isn't hooked up or loose, or a part of the intercooler system is loose. Check all lines and go from there.
Old Sep 24, 2013 | 10:05 PM
gkew's Avatar
sorry but I'm a noob, but where are the vacuum lines?
Old Sep 25, 2013 | 06:46 AM
They are the little rubber lines, less than a centimeter wide, that are around your intake area. I really dont know how to explain them well haha but they hook up to your intake and boost controller etc... hopefully that helps? Just look around your intake area and make sure there is not anything hanging loose or not snug over where it should be.
Id start with this simple fix solution then check your couplers on your FMIC and such after.
Old Sep 25, 2013 | 06:47 AM
If that doesnt help, I could possible take a pic sometime later today.... but that involves effort.
Old Sep 25, 2013 | 08:52 AM
I had some time at work and found this for you as an example. The lines like the ones that go into the Grimmspeed EBC in this picture are the ones you should check.
http://www.grimmspeed.com/catalog/im..._EVO_600_2.jpg
Old Sep 25, 2013 | 08:49 PM
gkew's Avatar
thanks alot InnonothingMR, I will have this checked first thinggg in the morning
Old Sep 26, 2013 | 05:18 PM
gkew's Avatar
well I checked ab out 6-8 lines and seems like theyre all well intact and so are my IC couplins
Old Sep 26, 2013 | 06:17 PM
Then I would check into some of the other issues given. Better to check the cheap possible issues before throwing the kitchen sink at it.
Old Sep 26, 2013 | 06:43 PM
xRoguex's Avatar
CAS could be going bad
Old Sep 26, 2013 | 06:55 PM
bdonIX's Avatar
make sure your intercooler piping hasnt popped loose anywhere.
