Order cv shafts online ?
Old Nov 4, 2013 | 03:12 PM
boos929's Avatar
Anyone know of a good site to get decently priced cv shafts preferably the hole assembly cars stock turbo with bolt ons Evo 8
Old Nov 4, 2013 | 03:33 PM
SilverShadow03's Avatar
What do you consider 'decently priced'?
$359.98 for both
http://www.extremepsi.com/store/prod...roductid=25082
$379.98 for both (Driveshaft Shop product but cheaper than buying from Driveshaft shop directly for some reason - Per Web Site)
http://www.jayracing.com/driveshaft-...le-p-8599.html
$399 for both
http://www.driveshaftshop.com/import...-a-racing-axle
Some have had good luck with Autozone...yes, I said Autozone. But others will say otherwise...See how others respond on your thread and go from there.
Autozone $174 for both
http://www.autozone.com/autozone/par...706373_0_78656
I would opt for the top 3 options I mentioned over Autozone...if it is in your budget.
Old Nov 4, 2013 | 06:23 PM
hiboost2.0's Avatar
Honestly if you go with autozone or any other aftermarket brand for that matter make 100% sure that they are the same length!!! I made that mistake when I first purchased my car. The axle was hyper extending itself because it was too short. Causing the boots to rip and since it was too short the seal between the transfer case and the axle did not seat properly on the axle, which made it leak. Mine leaked very badly for a few hundred miles and I didn't notice it, causing me my transfer case to run low on fluid and getting the "deathwhine".
My advice is to go OEM. If you're on a budget hit up a local evo shop and ask them if they have any used OEM axles around. If you don't have any around you a vendor near me that goes by "E-spec" has tons of them and will ship them out to you, here's his' link.
https://www.evolutionm.net/forums/ve...-part-2-a.html
Old Nov 5, 2013 | 06:28 AM
boos929's Avatar
Alright thanks for the advice i really don't want to out a used cv shaft in but I also don't want to order the wrong size has anyone actually bought and installed cv shafts that fit and work correctly? If so where from ? And should I do both sides or just the one that's clicking ? Thanks again for all the help
Old Nov 5, 2013 | 09:30 AM
barneyb's Avatar
If it is a boot leak that caused the axle to fail you only need one. BTW, front left and right are not the same.
Old Nov 5, 2013 | 12:38 PM
hiboost2.0's Avatar
If its just the boot thats ripped. You could always just get a boot kit for around $10-$20
Old Nov 6, 2013 | 10:38 AM
GTijoejoe's Avatar
I believe I paid something like ~$60 shipped from mitsubishiparts.net
It is the CV boot, it doesn't state it but it comes as a kit with all the grease and clamps.
Old Nov 6, 2013 | 11:55 AM
304MR's Avatar
AutoZone lasted me a month.
Driveshaft shop level 0 parts have been on back order for 6 months.
Jonno99
Aug 7, 2016 04:51 PM
bnr34rb26dett
Dec 13, 2015 06:51 PM
DSMLINK2003
Jun 5, 2015 07:11 PM
omarboy25
For Sale - Wheels / Tires / Suspension / Brakes
Dec 10, 2014 12:13 PM
willRalliart
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jun 12, 2010 11:16 AM
