Popping off T-clamps/Tial BOV?
Old Nov 9, 2013 | 02:50 PM
Jimmy Javelin's Avatar
Bottom Line up Front: I think my BOV spring is too stiff;
I'm popping off t-bolt clamps.
So, I switched from stock UICP to Buschur w/ Tial BOV VTA combo.
The first spring I had was the white spring (8lb) wasnt stiff enough, would stay open at idle.
I switched to the yellow/pink spring (12lb) based on recommendations from the trusted shop I always go to.
But, I had a feeling it was too much of a jump, and now whenever I attempt to boost I'm popping off t-bolts.
The plain (10lb) spring is what I'm thinking as the solution.
Thoughts?
Old Nov 9, 2013 | 02:57 PM
ReaperX's Avatar
So you're blowing off T-bolt clamps when you go from vacuum to boost, or from boost to vacuum?
Old Nov 9, 2013 | 03:02 PM
should be boost to vacuum. Because I dont have a chance to switch gears to go from vacuum to boost.
Old Nov 9, 2013 | 03:11 PM
ReaperX's Avatar
Run the 10# spring then, as well as make sure you're T-bolt clamps are secure. They shouldn't be popping off like that regardless.
StevenStarke
14
Dec 3, 2008 10:19 AM
Drooke
17
Jul 1, 2008 10:39 PM
kstpeter33
15
May 29, 2007 01:50 PM
QuickEvo
15
Oct 26, 2005 03:38 PM
Fourdoor
29
Nov 5, 2004 11:55 PM
