Help! Compressor surge!
Old Nov 17, 2013 | 11:45 AM
groundzero1v's Avatar
First day taking it to the track after upgrading with..
GSC S2 cams
dbb FP Black
ported im
ported exh mani
buschur 3" TBE
MAP o2 eliminator DP
3.5 ETS FMIC
buschur uicp and licp
1200cc incejtors,
Surges during acceleration then partial throttle over 10psi.. below 10 PSI the BOV just vents till it get to 0
example: accelerating on highway and then holding throttle to maintain speed.. then comp surge.. forces me to upshift right away
what should i check?
look at vid below
Old Nov 17, 2013 | 11:51 AM
silvertune's Avatar
Mine did that when my BOV developed a tear in the diaphragm.
Old Nov 17, 2013 | 12:00 PM
my BOV still vents.. its HKS btw.. was your BOV completely shut?
Old Nov 17, 2013 | 12:15 PM
llDemonll's Avatar
BOV still vents? what do you mean by that.
my synapse did that when the spring was too stiff so instead of holding open (say uphill at 2500rpm in 5th) it would bounce between open and closed and sound like that
Old Nov 20, 2013 | 01:55 PM
swapped my BOV to a Tial, still acts the same, so its not the BOV. Help
Old Nov 20, 2013 | 02:08 PM
illogicalmind's Avatar
Mines been doing that lately in 6th at partial throttle. I'm interested in knowing if anybody has an solution too. I was about to replace my stock BOV thinking that was the problem
Old Dec 4, 2013 | 10:36 AM
bump help, someone suggested wastegate surge.. so i preloaded the wga 3 turns.. and still the same...
Old Dec 4, 2013 | 02:52 PM
Booztd3's Avatar
mine does the same hks bov
Old Dec 5, 2013 | 08:20 AM
what turbos you guys have?
Old Dec 5, 2013 | 09:39 AM
cmcelroy09's Avatar
Mine does the exact same thing and I'm also running the dbb FP Black.
Old Dec 5, 2013 | 12:04 PM
What have you done to try to fix it?
Old Dec 5, 2013 | 01:40 PM
cmcelroy09's Avatar
I just bought the car so I haven't really done anything yet to try and figure it out. It sure is annoying though!
Old Dec 5, 2013 | 05:57 PM
cfdfireman1's Avatar
Put the stock recirc valve back on and tell us what it does or install a lighter spring in the tial.
Old Dec 5, 2013 | 09:10 PM
tial already has 8psi spring on it
Old Dec 6, 2013 | 07:24 AM
Try the 6.
