what kind of injectors and head studs are these?
Old Dec 10, 2013 | 10:09 AM
jarred15801's Avatar
I have these injectors that came along with a bunch of other stuff when I bought my car. Any idea what kind they are, size, or any value? I also have a box with these head studs in it. I assume these are the stock ones and were just placed in this box after the ARP studs were installed?
Attached Thumbnails what kind of injectors and head studs are these?-20131120_164348_resized.jpg   what kind of injectors and head studs are these?-20131120_164353_resized.jpg   what kind of injectors and head studs are these?-20131120_164404_resized.jpg   what kind of injectors and head studs are these?-20131120_164319_resized.jpg   what kind of injectors and head studs are these?-20131120_164311_resized.jpg
Old Dec 10, 2013 | 11:01 AM
steven121's Avatar
Google.com -> type in part number
Old Dec 10, 2013 | 11:07 AM
I tried google. just took me to some other injectors that are not the ones pictured. I was hoping someone would recognize them just my sight.
Old Dec 10, 2013 | 11:28 AM
ReaperX's Avatar
Not sure on the injectors but those look to be stock head bolts.
Old Dec 10, 2013 | 12:23 PM
heel2toe's Avatar
Stock headbolts for sure.
As to to the injectors I'd recommend reaching out to some injector manufactures to see if they can help you out. I've had great experiences with FIC so that would be my first point of contact. Im almost positive those arent theirs however they should be able to help identify and if all else fails they could certainly test them, clean them if necessary and spec them out for you.
Old Dec 10, 2013 | 01:15 PM
thank you I will probably do this.
Old Dec 10, 2013 | 01:23 PM
todd6027's Avatar
Rochester (PTE injectors)
17113738 - 50 lb/hr
17113741 - 55 lb/hr
17113814 - 65 lb/hr
17113742 - 75 lb/hr
17113743 - 85 lb/hr
17113744 - 95 lb/hr
Lbs/Hr to CC formula = (lbs/hr) * 10.5
17113738 - 525cc
17113741 - 577cc
17113814 - 682cc
17113742 - 787cc
17113743 - 892cc
17113744 - 997cc
Old Dec 10, 2013 | 03:07 PM
According to that chart they are 787cc injectors. Value on them once they are cleaned and speced?
Old Dec 10, 2013 | 03:23 PM
xXANCHORMONXx's Avatar
Maybe 100-150
They would be for a mild pump gas setup.
Evo8Emperor
18
Dec 27, 2014 12:57 PM
wacboyjulian
Oct 3, 2014 11:53 AM
BadassEvo8
Jul 31, 2014 01:20 AM
qlitv
32
Apr 6, 2008 02:01 PM
bigric09
10
Jun 15, 2007 06:00 PM
