Boost guage power sources.
Old Dec 13, 2013 | 01:53 PM
TS Goofy's Avatar
Hey. I'm trying to install my STRI boost guage in my evo 9. Its going to be located above my HVAC conttols along with a innovate wideband. I picked up a fuse with some wire attatched to it to tap into my fuse box. Either constant 12v or Ignition 12v. Where could I find an ignition 12v or constant 12v behind my center dash for my guages? I don't have a multimeter currently.
So for who have their guages setup where I want mine, what power sources did you tap into? Or any suggestions?
Old Dec 13, 2013 | 02:17 PM
llDemonll's Avatar
i would use the same one that powers the dash cluster, fuse 2 i believe
for illumination, I used the green (i think it was green) wire from the clock
gauges are powered whenever the ignition is ON, only lit up with running lights or headlights are on
edit: Fuse 2 is the gauges, not fuse 3
Old Dec 13, 2013 | 06:16 PM
TS Goofy's Avatar
Originally Posted by llDemonll
i would use the same one that powers the dash cluster, fuse 3 i believe
By illumination you mean the dimming?
Old Dec 13, 2013 | 06:44 PM
egis's Avatar
No,glowing.
Old Dec 13, 2013 | 07:58 PM
llDemonll's Avatar
correct, the glowing portion
gauges need two power sources for some (i have autometer ES), so the gauge itself is powered and also the backlights of the gauge are powered but they are separate from each other. others are different and are powered by the controller (defi) so you'd only need the one power source out of the fuse box
Old Dec 13, 2013 | 08:28 PM
Capt Leung's Avatar
I have mine tapped into the radio harness.
turbotaloon95
May 16, 2017 01:57 PM
asdfasdf128
Apr 17, 2016 06:24 PM
chu
Jun 13, 2008 11:45 AM
TREVORSEVOVIII
Jan 6, 2008 10:07 AM
theGman911
11
Jul 13, 2006 09:59 PM
