Strange starter problem. Help me :)
Old Dec 13, 2013 | 06:51 PM
apedog's Avatar
Car is 2005 Evo 8
Ok so im having an issue right now with my starter not wanting to start my car. I just replaced it with a new one. I can hear it come out but it does not spin. So I know its getting power but for some reason not wanting to spin. My battery has been tested and it is fine. However about a month back I was getting ALOT of corrosion on the positive battery terminal but it has stopped.
Would a possible problem be that the wire coming from the positive terminal on the battery corroded so much now there is an open/resistance somewhere going to the starter?
Any help would be appreciated
Old Dec 13, 2013 | 07:56 PM
01 Trans-Am WS6's Avatar
Its the ignition switch. Cheap & easily replaced.
Read through these, if similar, that is your solution.
https://www.evolutionm.net/forums/ev...l#post10365897
This is the orig thread I made about the issue I was having with my Evo 8 not starting
https://www.evolutionm.net/forums/ev...lp-advice.html
Old Dec 13, 2013 | 10:44 PM
sadc's Avatar
Check the wire thats going from the battery to the starter. I, my self had that problem.
Old Dec 13, 2013 | 11:05 PM
shrtstuff89's Avatar
make sure you have the positive, the ground and the signal wires all hooked up. the signal wire can easily slip off the little clip on the starter
Old Dec 14, 2013 | 10:09 AM
apedog's Avatar
Sounds like ignition switch is my next choice then after reading through some threads. I took the steering column cover off and when I would turn the key I would watch the switch and would see like a spark light of some sort right at the switch. Ill post back if that was the problem.
Thanks everyone
Old Dec 14, 2013 | 11:06 AM
Bhsj13's Avatar
Yes, check all the above and also make sure the starter bolts are secure. I had a problem before when all it took was to tighten down on one starter bolt. Good luck!
Old Dec 14, 2013 | 08:36 PM
daniel577h's Avatar
Check voltage at the starter cable the fat one.
Old Dec 15, 2013 | 08:49 PM
apedog's Avatar
Ended up being way to much corrosion on the positive battery cables after realizing replacing the switch wasent it Its alright though at least I have a new starter and ignition switch now
Old Dec 17, 2013 | 05:54 PM
Wow isn't that something? At least your car is now covered for quite a while in the starting dept.
lbwilliams44
Jul 6, 2020 03:32 AM
fjm9898
Jun 20, 2016 10:12 AM
raven1231
Jan 25, 2013 03:57 PM
bnr34rb26dett
10
Dec 12, 2010 07:29 PM
tuner
Sep 30, 2003 09:32 AM
