Water pump cap blew off
Old Jan 8, 2014 | 04:32 PM
Toekneee!'s Avatar
Hey guys. So yesterday I switched out my Injen uicp for the Nisei short route one.
Pretty sure that's irrelevant but after I went for a test drive and noticed a loud pop. Car was fine until I pulled over and noticed smoke. The cap on my water pump popped off from the pressure I guess.
Anyone have an experience like this? Why did this happen? Fresh water pump/timing belt/tensioner blah blah. Just had it serviced.
Old Jan 8, 2014 | 04:36 PM
jfa_evo's Avatar
if it's broke, repair it. if you never replace it, then the water pump not last forever.. so consider the cost for 60k service aprox
Old Jan 8, 2014 | 04:43 PM
Toekneee!'s Avatar
Everything was just replaced as stated in my post. Brand new.
I'm wondering why this would happen. Just a bad pump?
Old Jan 8, 2014 | 07:31 PM
ch53avitech's Avatar
I had my #4 cylinder and tranny cap blow off at the same time a couple months ago. More than likely there was a small air pocket in the cooling system. That air will turn into steam and that steam has nowhere else to go but out. I just replaced my caps with new OEM ones, re-flushed my coolant and I was on my way. Haven't had a problem since.
Old Jan 9, 2014 | 06:00 AM
Fast_Freddie's Avatar
Veteran: Navy
That is from a bubble in the system... seems like it wasn't burped all the way...
Old Jan 9, 2014 | 07:53 AM
andrewzaragoza's Avatar
hope air in the system. this also happens when you lift the head. make sure there is no oil in your coolant.
kaj
Site Feedback / Suggestions
Nov 27, 2016 03:33 PM
azboost92
10
May 10, 2016 11:01 AM
lghtngyello03
Mar 19, 2016 04:25 PM
NOMIEZVR4
Jun 13, 2014 08:16 AM
Peteypab2133
Aug 18, 2006 08:28 AM
