oil leak problem
Old Jan 10, 2014 | 04:45 PM
rjfg's Avatar
oil leak problem
I'm hoping someone can help me here I've developed an oil leak on my car tgat I cannot seem to diagnose. The car will run fine and idle fine with no leaks but when I turn the car odd it will drip untill the oil settles in the pan. I'm havibg a hard time pinpointing the leak and I'm hopibg for some insight.
Cheera
Colton
Old Jan 10, 2014 | 07:20 PM
MRolla's Avatar
Pic could help or a general area of the leak
Old Jan 10, 2014 | 07:39 PM
rjfg's Avatar
Above the starter
Old Jan 10, 2014 | 09:13 PM
jason42003's Avatar
Is it for sure engine oil or could it be gear oil, they smell differently. If its engine oil it could be the turbo oil lines, rear main seal, valve cover gasket, head gasket or cam sensors depending on how high up it goes. Those could all possibly leak oil in that area but if you don't have coolant in oil or oil in coolant than I wouldn't worry about head gasket.
Old Jan 11, 2014 | 01:13 AM
rjfg's Avatar
I know its not the head gasket I checked that first.
Old Jan 11, 2014 | 01:25 AM
shrtstuff89's Avatar
Oil pan, oil return lines, theres a bunch of places. Track it and find how high up the oil goes
Old Jan 11, 2014 | 07:05 PM
WikdEvo's Avatar
Going to need more of a description and some pics to help identify.. We are in the dark here. You say starter area. So that's by the turbo. Check the oil feed for the turbo, cam angle sensor area, and the valve cover.
mrbonilla
Aug 29, 2016 11:33 AM
EvilDSM97
Jul 16, 2016 06:10 PM
changocox1322
Feb 24, 2016 07:09 PM
JGNERAEVO9
Feb 5, 2016 05:13 PM
Tiresomejunk
Dec 14, 2015 04:53 AM
