How stiff is your Evo?
Old Jan 22, 2014 | 08:09 PM
  #31
Viegasjuice's Avatar
I'll have to go play around with it then. Sounds like these cars hold up well.
Old Jan 22, 2014 | 08:18 PM
  #32
deeman101's Avatar
Here's a hint to make this trick work well. Line up your floor jack with front door handles. Both the front and rear will come up at the same time. Assuming you didn't change the weight balance significantly with mad weight reduction. I swap brake pads and tires for every track day and this is a trick that let's me do it quickly.
Old Jan 22, 2014 | 09:37 PM
  #33
That sounds super convenient. Thanks.
Old Jan 23, 2014 | 05:40 AM
  #34
Iowa999's Avatar
That is not a recommended jacking-point.
Old Jan 23, 2014 | 06:45 AM
  #35
deeman101's Avatar
The steel pinch rail here is in 2 layers instead of 3 like at the jack point. But I always prefer putting the jack stand itself at the jack point. And both points will bend if you are rough with it, but nothing bad happens even after it bends. Some racers actually just hammer it all down.
I used to use the front crossmember and rear diff as the jack points. Then I actually bent the OEM front cross member from repeated jacking. Albeit I was jacking a few inches behind the jack pad because thats the only way to get meaningful lift with a 1.5ton jack. So now I do it at the pinch rail, and it feels much safer too as long as the opposite 2 wheels are on the ground.
Old Jan 23, 2014 | 10:23 AM
  #36
Terror Rising's Avatar
How much lift did you need? I have a Harbor Freight 1.5 ton aluminum "racing" jack that I use. It's plenty enough to lift the front end off the ground so I can change camber using the jack pad.
Old Jan 23, 2014 | 08:21 PM
  #37
EVO6GSR's Avatar
http://www.flickr.com/photos/77990917@N06/8357060714/
Old Jan 23, 2014 | 08:34 PM
  #38
deeman101's Avatar
I have the exact same jack (rebranded) that I take to events. Its a POS eh? But its light and portable. I like it at a height where I can have my back comfortable as I change pads.
Old Jan 24, 2014 | 07:21 AM
  #39
As I said earlier everyone knows when I'm changing my camber due to the squeaking from the jack. But, it fits perfectly in the rear seat footwells, is light as hell, and doesn't leak down. So, it fits the bill for me.
Old Jan 25, 2014 | 07:33 AM
  #40
jrainwater's Avatar
I had the exact same jack and it crapped out on me after 1.5 years. I bought another one and its been fine for a year now. I like the jack a lot and it works fine. When it doesn't break lol.
Old Feb 4, 2014 | 02:59 PM
  #41
mk12arv's Avatar
awww my poor evo is loose and sloppy, too many track days i guess
Sheasta
Oct 24, 2015 12:42 AM
FunBeny
May 18, 2012 06:37 AM
andrewRA
Jun 7, 2011 09:14 PM
Speed MR 857
Aug 14, 2010 02:41 AM
