Oil pump leak (video)
Old Jan 30, 2014 | 09:26 PM
WikdEvo's Avatar
I'll pull a few caps tomorrow and check. Do far from looking at the BS bearings they look perfect.
Old Apr 17, 2014 | 01:48 AM
Gadiel's Avatar
Good info
Good info on this post. Thanks for the info
Old Apr 17, 2014 | 07:14 AM
fallenauthority's Avatar
Even if you don't find damage to your rod and main bearings you should still pull the motor and have it torn down and thoroughly cleaned. All of the aluminum that your oil pump gear and oil pump shaft machined out of that front cover went somewhere. Your oil passages are filled with fine debris now guaranteed. Fix it right fix it once.
aviseevuoptical
Feb 28, 2016 12:24 PM
tsidrift1
Jul 28, 2015 08:57 AM
Craig King
26
Oct 31, 2012 05:42 AM
Steve_P
Jun 1, 2011 08:18 AM
adWRXi
Apr 7, 2010 03:31 PM
