6 spd trans oil seal leak at axle- anyone else?
Old Feb 4, 2010 | 02:18 PM
Steve_P's Avatar
I have 20k miles and just noticed an oil leak at the LH axle's oil seal. It's minor right now but will eventually have to be changed. The RH side is dry as it should be
I was just curious if anyone else has had this problem. I searched and came up empty.
Old Feb 4, 2010 | 02:20 PM
Evo IX MR's Avatar
Damn you! I'm gonna have to check my car now. Never heard of this issue before so I'm fairly certain it's not common.
Old Feb 5, 2010 | 08:21 AM
Steve_P's Avatar
The axle hasn't been out and nothing I know has happened that could justify it failing so soon; it must just be one of those one in a million type early failures.
I have seen the threads where the sheetmetal plug pops out of the side of the 6 spd so I changed that a while back. The original one was a fairly loose fit, I could tap on it and move it, and the new one went in much tighter. Not sure if you've seen those threads. The seal was dry then but has obviously died between then and now.
Old Feb 8, 2010 | 10:31 AM
Steve_P's Avatar
some pics... It's pretty minor at this point
Old Feb 8, 2010 | 04:32 PM
Erik@MIL.SPEC's Avatar
Had this same problem myself. Had to get it replaced eventually....had tranny fluid all over the place.
Old Feb 9, 2010 | 10:21 PM
DIDYSIS's Avatar
Have not seen this on mine thank goodness and I am knocking on wood just incase
Old Apr 15, 2010 | 10:15 PM
DSM2EVO's Avatar
happened to me today try putting a new seal but the axle and bearing had ridges and grooves that look bad anyone know from what?
Old Jun 1, 2011 | 08:18 AM
DSM2EVO's Avatar
bump need some help
BaLListic_EVO
24
Oct 13, 2016 02:59 PM
jdmauto
Aug 6, 2016 06:49 PM
stunna2o1
Jan 25, 2016 07:02 PM
AcePitcher11
17
Feb 4, 2012 10:54 AM
inteleric1983
Jun 22, 2011 04:35 AM
